Hi All,
I've got myself a little confused over how I can use relevant within
XLSForms and it may be what I'm trying to do is not possible.
I'm trying to implement skip logic that is based on 2 previously select
variables, if you look at the attached example, when I use
the http://opendatakit.org/use/xlsform/ to convert ready for testing I
receive an error:
Error: There has been a problem trying to replace ${districts} with the
XPath to the survey element named 'districts'. There is no survey element
with this name.
This is because of the relevant I've used on row 60, i can't find any
example of multi-relevant so maybe it's just my syntax - i hope it's
something quick and simple.
cheers
dan
errorexample.xls (39 KB)
Dan,
Not sure if this is the problem, but you have:
selected(${q2012year}, 'yes') and select(${districts}, 'nyanga'
That's missing a closing ) at the end, which might be confusing things.
Chris
On Thu, Jan 10, 2013 at 11:42 AM, Daniel Probert wrote:
Hi All,
variables, if you look at the attached example, when I use the
receive an error:
with this name.
cheers
dan
good spot i think i just worked it out i needed to use district instead of
districts now it will process and seems to be working correctly..
On Thursday, January 10, 2013 9:55:08 AM UTC, Christopher Robert wrote:
> Dan,
> Best,
> Chris
> On Thu, Jan 10, 2013 at 11:42 AM, Daniel Probert <dpro...@camfed.org wrote:
>> Hi All,
>> receive an error:
>> with this name.
>> cheers
>> dan
