Dear friends,
I'm working on a form which has two repeat groups. The first one records
the information about all household members and another one recording the
education of the household member. Problem is that I want to limit the
occurrence of the second group based on the number of household members
recorded in the first group. It seems that repeat_count should be used for
the job but it makes ODK collect crash. If I remove the corresponding
syntax, it works fine.
Here is more detailed structure of my form (I've omitted unnecessary
fields):
repeat_count begin repeat roster Household members calculate
mid text name Name select_one gender_list gender Gender integer
age Age calculate age6 calculate agem select_one yesno empl Are
you employed end repeat begin repeat education Education
count(${roster}) calculate rname calculate rpos calculate age6_c
calculate age6_d Was this question asked? Y/N select_one edu_list
edu6 What's the highest level of education ${rname} has achieved? end
repeat
Thanks in advance,
David
David,
What happens if you use an output to see what you get when call
count($roster). Do you get the number you expect?
What happens if you put a number in repeat_count. Does it work then?
On Wed, Jun 11, 2014 at 5:36 AM, David Sichinava david@sichinava.ge wrote:
Dear friends,
I'm working on a form which has two repeat groups. The first one records the information about all household members and another one recording the education of the household member. Problem is that I want to limit the occurrence of the second group based on the number of household members recorded in the first group. It seems that repeat_count should be used for the job but it makes ODK collect crash. If I remove the corresponding syntax, it works fine.
Here is more detailed structure of my form (I've omitted unnecessary fields):
repeat_count
calculate mid
text name Name
integer age Age
calculate age6
calculate agem
select_one yesno empl Are you employed
end repeat
begin repeat education Education count(${roster})
calculate rname
calculate rpos
calculate age6_c
select_one edu_list edu6 What's the highest level of education ${rname} has achieved?
end repeat
Thanks in advance,
David
Yaw,
When I load blank form, it yields following error message: XPath
evaluation: type mismatch expected xpath path, got xpath expression:
"[count(/oecd[It's my form name]/responde[it's group name]/roster[it's
repeat name]), null]".
I've added calculate field and note which would compute and display the
count number of repeats, but I'm getting similar error with the following
tip: "you may need to use the indexed-repeat() function".
David
On Thu, Jun 12, 2014 at 7:21 PM, Yaw Anokwa wrote:
David,
Dear friends,
fields):
repeat_count
calculate mid
text name Name
integer age Age
calculate age6
calculate agem
end repeat
calculate rname
calculate rpos
calculate age6_c
has achieved?
end repeat
Thanks in advance,
David
https://groups.google.com/d/topic/opendatakit/OZ_xUx5iZII/unsubscribe.
David Sichinava | GIS and Database Analyst | CRRC Georgia
+995 598 555 381 | http://www.datablog.ge
Hi David,
This might be one of those issues where referencing repeats in XLSForm
causes problems. Or it just might be that count cannot be updated
inside a loop.
Either way, I don't have a ton of cycles to figure it out, so I've
filed it at https://code.google.com/p/opendatakit/issues/detail?id=1020.
If you can provide a small test form you can attach to that issue,
it'll keep the core team track down the problem.
On Thu, Jun 12, 2014 at 9:44 AM, David Sichinava david@sichinava.ge wrote:
Yaw,
When I load blank form, it yields following error message: XPath evaluation: type mismatch expected xpath path, got xpath expression: "[count(/oecd[It's my form name]/responde[it's group name]/roster[it's repeat name]), null]".
I've added calculate field and note which would compute and display the count number of repeats, but I'm getting similar error with the following tip: "you may need to use the indexed-repeat() function".
David
On Thu, Jun 12, 2014 at 7:21 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
David,
Dear friends,
repeat_count
calculate mid
text name Name
integer age Age
calculate age6
calculate agem
end repeat
calculate rname
calculate rpos
calculate age6_c
end repeat
Thanks in advance,
David
You received this message because you are subscribed to a topic in the Google Groups "ODK Community" group.
To unsubscribe from this topic, visit https://groups.google.com/d/topic/opendatakit/OZ_xUx5iZII/unsubscribe.
To unsubscribe from this group and all its topics, send an email to opendatakit+unsubscribe@googlegroups.com.
Hi Yaw,
Sorry for the delayed response.
Actually, it appears that there's a workaround - I put a calculate field
OUTSIDE of the first repeat group and then referred to this variable in the
second group's repeat-count property. Something like:
end repeat / household roster/
cntRoster / count(${roster})
begin repeat / repeat_count / ${cntRoster}
Hope it helps other people as well,
D.
On Wed, Jun 18, 2014 at 12:27 AM, Yaw Anokwa wrote:
Hi David,
inside a loop.
Yaw,
David
David,
Dear friends,
fields):
repeat_count
calculate mid
text name Name
integer age Age
calculate age6
calculate agem
end repeat
calculate rname
calculate rpos
calculate age6_c
end repeat
Thanks in advance,
David
