Hello,
I have a repeat group wherein I collect data about children, one of the
fields is gestation age
am failing to create a constraint on gestation age, where if in the first
group gest age is 35 in the second group it should not be different
Any Help is welcome
Hi Kalande,
Do you want the gestation age of the first loop is the same than the second
loop or only if its value is 35
I want second loop gest to be same as first, so that incase someone enters
something diff in second loop it rejects, i.e using it as valudation check
On Jun 21, 2015 6:58 PM, "Pierre Anthony Garraud" wrote:Hi Kalande,
second loop or only if its value is 35--
We assume Member is the name of your repeat group. You must a variable a
calculated variable "gest1" and in the calculation, put position(..).
if(position(..)=2,.=indeexed-repeat(${age},${Member},1),.<100)
Try this
Pierre
2015-06-21 11:39 GMT-07:00 Ayoub Kakande :I want second loop gest to be same as first, so that incase someone enters
On Jun 21, 2015 6:58 PM, "Pierre Anthony Garraud" pagarraud1@gmail.com wrote:Hi Kalande,
We assume Member is the name of your repeat group. You must have a
in the constraint of the variable age , put this formula :
I think i am clear now
Try this
2015-06-21 11:46 GMT-07:00 Pierre Anthony Garraud :Hi,
calculated variable "gest1" and in the calculation, put position(..).if(position(..)=2,.=indeexed-repeat(${age},${Member},1),.<100)
Try this
Pierre
2015-06-21 11:39 GMT-07:00 Ayoub Kakande akakande@gmail.com:
enters something diff in second loop it rejects, i.e using it as valudation
check
Groups "ODK Community" group.
