Is it possible to have a repeat function in a repeat function? If yes, how
do I do so?
do I do so?
Yes. Just put the repeat inside the repeat. And just to have a
complete answer, you can put as many repeats inside a repeat as you'd
like.
Can you please help me check what's wrong? I get an indexed-repeat error
when I am choosing another "Item_type".
SPREADER.xlsx (15 KB)
Hi Yaw,
Its okay already. I found my mistake.
Thanks for the help.
