Sorry to open this question again but I am having a problem when creating a repeat within a repeat. I used to have it working but now it is not working. I am able to convert it to XML and filling the survey but when trying to extract it using ODK Briefcase, the form is not appearing in the pull list. I have also tried to check form definition and I receive this error "Bad form definition file. Please select another file."
I attached an image of the data flow that I need and how I used to do it. Do you have any suggestions on how to fix it? Are there any updates to ODK that could prevent such repeats?
ODK Collect v1.19 on Samsung Galaxy Tab 9
ODK Briefcase v1.4.5 Production and ODK-Briefcase-v1.13.1 on Microsoft Windows 10 x64
After fiddling with the form and Briefcase, I've got this error:
2019-02-12 20:32:15,002 [AWT-EventQueue-0] ERROR o.o.b.ui.reused.source.Source - Error parsing form
org.opendatakit.briefcase.util.BadFormDefinition: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: Javarosa failed to construct a FormDef. Is this an XForm definition?
at org.opendatakit.briefcase.model.OdkCollectFormDefinition.<init>(OdkCollectFormDefinition.java:64)
at org.opendatakit.briefcase.ui.reused.source.Source$FormInComputer.onSelect(Source.java:423)
at org.opendatakit.briefcase.ui.reused.source.SelectSourceForm.lambda$new$0(SelectSourceForm.java:43)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6539)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Caused by: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: Javarosa failed to construct a FormDef. Is this an XForm definition?
at org.opendatakit.aggregate.parser.BaseFormParserForJavaRosa.<init>(BaseFormParserForJavaRosa.java:464)
at org.opendatakit.briefcase.util.JavaRosaParserWrapper.<init>(JavaRosaParserWrapper.java:13)
at org.opendatakit.briefcase.model.OdkCollectFormDefinition.<init>(OdkCollectFormDefinition.java:62)
... 38 common frames omitted
Caused by: org.javarosa.xform.parse.XFormParseException: Binding path [null] not allowed with parent binding of [/Test2/families_assessment/members_assessment]
at org.javarosa.core.model.FormDef.getAbsRef(FormDef.java:127)
at org.javarosa.xform.parse.XFormParser.getAbsRef(XFormParser.java:1545)
at org.javarosa.xform.parse.XFormParser.parseGroup(XFormParser.java:1473)
at org.javarosa.xform.parse.XFormParser.access$300(XFormParser.java:119)
at org.javarosa.xform.parse.XFormParser$1$8.handle(XFormParser.java:253)
at org.javarosa.xform.parse.XFormParser.parseElement(XFormParser.java:539)
at org.javarosa.xform.parse.XFormParser.parseGroup(XFormParser.java:1513)
at org.javarosa.xform.parse.XFormParser$1$7.handle(XFormParser.java:247)
at org.javarosa.xform.parse.XFormParser.parseElement(XFormParser.java:548)
at org.javarosa.xform.parse.XFormParser.parseDoc(XFormParser.java:455)
at org.javarosa.xform.parse.XFormParser.parse(XFormParser.java:366)
at org.opendatakit.aggregate.parser.BaseFormParserForJavaRosa.<init>(BaseFormParserForJavaRosa.java:462)
... 40 common frames omitted
It turns out Briefcase 1.13.1 uses a JavaRosa version that doesn't support your form, but we're planning a new release for next week that will be able to pull it. I'll try to keep you updated about this.
Thank you for taking this problem into your consideration. I have tested the updated version Briefcase 1.14.0 and now it is working fine. Much appreciated.
