I just wanted to know if ODK supports questions of the following kind,
and how they would be implemented:
Q1: Name
Q2: Age
Q3: How Many Children Do You Have?
[If Q3.value > 0, repeat Q4-Q7 for Q3.value times]
Q4: What is the age of the Nth child
Q5: When was the Nth child immunized
Q6: How many times has the Nth child suffered from Malaria
Q7: What is the sex of the Nth child
our form design tool doesn't handle repeats yet so you'll have to code it up
by hand. a more detailed spec of how to build repeats is available at http://code.javarosa.org/wiki/xform.
Q1: Name
Q2: Age
Are there any editors that support JavaRosa repeating groups (other
than notepad)? Is there any work currently happening on the odk
build application? If not would you like some help on this?
Regards
Neil
On May 29, 1:56 am, Yaw Anokwa wrote:
> we do support repeats. an example of this repeating section can be found in
> the household form athttp://code.google.com/p/opendatakit/source/browse/Household+Survey.x...
> by hand. a more detailed spec of how to build repeats is available athttp://code.javarosa.org/wiki/xform.
> if you have questions as you build your form, please send them to
> opendatakit-implementers@googlegroups.com
> On Fri, May 28, 2010 at 07:09, Pr0f3t wrote:
> > Hello all,
> > Q1: Name
> > Q2: Age
> > Q8: Other none repeating question...
> > Luke.
our form design tool doesn't handle repeats yet so you'll have to code it up by hand. a more detailed spec of how to build repeats is available at http://code.javarosa.org/wiki/xform.
Purcforms seems to have a repeat field type. Check it out ..
On Jun 8, 10:05 am, nap wrote:
> Hi,
> Regards
> Neil
> > > Hello all,
> > > Q1: Name
> > > Q2: Age
> > > [If Q3.value > 0,repeatQ4-Q7 for Q3.value times]
> > > Luke.
We're working on a lot of things in ODK Build. I'll count this as a vote for repeated groups.
—Clint
Q1: Name
Q2: Age
in the household form at http://code.google.com/p/
opendatakit/source/browse/Household+Survey.xml?repo=forms.
"seems to". I had looked at Purcforms, but hadn't managed to get the
repeating group functionality to work. Have you got it to support the
"how many children" scenario that you outlined at the beginning of
this thread?
> > Hi,
> > Regards
> > Neil
> > > > Hello all,
> > > > Q1: Name
> > > > Q2: Age
> > > > Luke.
Not fully - we're having to make customizations to the xml that
purcforms outputs, but are getting close. Joseph, copied in is working
closely on this and can offer input.
Luke.
> this thread?
> > Purcforms seems to have arepeatfield type. Check it out ..
> > > Hi,
> > > Regards
> > > Neil
> > > > > Hello all,
> > > > > Q1: Name
> > > > > Q2: Age
> > > > > Luke.
I have created a custom storage system for the data submitted from ODK
Collect and I would like to know what would be the best possible
solution to storing repeat data?
Aggregate stores the repeated data in a separate database table.
Cheers,
Waylon
