The first is to supply a ':requiredMsg' translation in the section
for that prompt.
<text id="yourpromptfieldpath:requiredMsg">
<value>Note for Translator: You must enter this value!</value>
</text>
This allows translations for the message.
The same is possible for the constraint message. You can specify a
":constraintMsg" translation.
(2) ODK Collect also accepts a jr:requiredMsg attribute on the tag,
in a manner identical to the jr:constraintMsg. The disadvantage of this
mechanism is that it does not support multiple translations.
On Wed, Mar 30, 2016 at 8:54 AM, Greg wrote:
I want to display a custom message when a required question isn't
answered. I thought this would be easy but I'm not doing something right.
If I make a bind like this:
I thought all I had to do is add required_message to the same bind like so:
However, it doesn't seem to work like that. I can't seem to find any
reference showing the actual code of how it works.
I'm sure this is ridiculously simple but if anyone could show me the
actual code I would greatly appreciate it.
I used option 2, just because this is a quick form and we are very
uni-lingual here and it worked great in ODK Collect 1.4.7 on Aggregate
1.4.7. Thank you again!
Validate 1.4.6 doesn't like it though. I'll include the error I received
below for two lines in my form just in case you find it useful.
Otherwise I'm happy.
Parsing form...
Title: "Goose Survey"
XForm Parse Warning: Warning: 1 Unrecognized attributes found in Element
[bind] and will be ignored: [requiredMsg] Location:
Problem found at nodeset: /html/head/model/bind
With element <bind nodeset="/GooseSurvey/GPSpoint" type="geopoint"
requiredMsg="A GPS point is required for the egg nest." required="true()"/>
With element <bind nodeset="/GooseSurvey/ParkList" type="select1"
requiredMsg="Please indicate which park you are counting geese or eggs in."
required="true()"/>
required="true()"/>
>> Xform parsing completed! See above for any warnings.
Xform is valid! See above for any warnings.
On Wednesday, March 30, 2016 at 12:54:41 PM UTC-6, Mitch Sundt wrote:
There are two ways to define this.
(1) most useful:
for that prompt.
</text>
On Wed, Mar 30, 2016 at 8:54 AM, Greg <greg....@edmonton.ca <javascript:>> wrote:
so:
email to opendatakit...@googlegroups.com <javascript:>.
University of Washington mitche...@gmail.com <javascript:>
Parsing form...
required="true()"/>
required="true()"/>
(1) most useful:
section for that prompt.
</text>
tag, in a manner identical to the jr:constraintMsg. The disadvantage of
this mechanism is that it does not support multiple translations.
Groups "ODK Community" group.
