Required Message
It brings the message of two languages ​​in one message, while it Should brings one of each language in the same language section. Do you know what the problem is?
One thing that I notice here is that the language code for both languages are incorrect. Here are the correct codes:
Dari: (prs)
Pashto: (ps)
In future you can refer to this document to find out the language code of any language. So in the column heading you need to put:
required_message::دری(prs)
required_message::پشتو(ps)
Make sure you change the language code in label columns as well. See if this fixes the issue, if not then please share a sample Form with the same issue and version number of the ODK Collect.
Thanks it worked very well
Hint: Syntax seems defined with a blank before the ( ...), See https://support.kobotoolbox.org/language_xls.html?highlight=multiple+language
