Hi, There is some way, maybe with constraint? for making required a string field if in a previous selection is not selected any choice or maybe a "None" choice? All this inside a same Field-list
Thanks!
Thanks!
If it's in one field-list it's not possible.
Is the usecase you are trying to accomplish here the equivalent of select_one, or_other? (ie if they select 'None' from the select_one list, you have a subsequent question enabling the user to enter a custom value.
Yeah, but I want it in the same "Page" or "Field-list"
make the enclosing group "customer page" a field-list?
