# Retrieving answers from a repeat group and using them to create multiple-choice lists for two levels of questions
**URL:** <https://forum.getodk.org/t/retrieving-answers-from-a-repeat-group-and-using-them-to-create-multiple-choice-lists-for-two-levels-of-questions/42454>\
**Category:** Support\
**Tags:** odk-xlsform\
**Created:** [August 1, 2023, 4:24am UTC](https://forum.getodk.org/t/retrieving-answers-from-a-repeat-group-and-using-them-to-create-multiple-choice-lists-for-two-levels-of-questions/42454 "2023-08-01T04:24:52Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Andres\_E](https://getodk.b-cdn.net/user_avatar/forum.getodk.org/andres_e/32/22183_2.png) [@Andres\_E](https://forum.getodk.org/u/Andres_E)\
**Post date:** [August 1, 2023, 4:24am UTC](https://forum.getodk.org/t/retrieving-answers-from-a-repeat-group-and-using-them-to-create-multiple-choice-lists-for-two-levels-of-questions/42454/1 "2023-08-01T04:24:52Z")
</div>
**1. What is the issue? Please be detailed.**
Hello, I would like to retrieve the answers that are within a repeat group and create a multiple-choice question based on those responses. I want to do this at two levels for the repeat group. I have already achieved the first level (see question E\_7), but I am still missing the second level. I have tried several approaches, but I haven't been successful because it's within a repeat group. I have reviewed the discussions ([https://community.kobotoolbox.org/t/cant-create-a-select-multiple-question-based-on-a-list-generated-by-responses/30637/5](https://community.kobotoolbox.org/t/cant-create-a-select-multiple-question-based-on-a-list-generated-by-responses/30637/5)), and they have been helpful, but I still haven't achieved the desired result. The outcome I need is that for each response in C\_2 (plots), there is a list of answers from D\_9 (parcels) to create multiple-choice lists in questions E\_7 and E\_8.
Your help is sincerely regarded.
[trial.xlsx](https://forum.getodk.org/uploads/short-url/xvzxe0Ol4hr8ol2JgZ6aZKnHXex.xlsx) (18.0 KB)
**Author:** ![Grzesiek2010](https://getodk.b-cdn.net/user_avatar/forum.getodk.org/grzesiek2010/32/2881_2.png) [@Grzesiek2010](https://forum.getodk.org/u/Grzesiek2010)\
**Post date:** [August 10, 2023, 5:52pm UTC](https://forum.getodk.org/t/retrieving-answers-from-a-repeat-group-and-using-them-to-create-multiple-choice-lists-for-two-levels-of-questions/42454/2 "2023-08-10T17:52:44Z")
</div>
Hi @Andres_E
Welcome to the ODK forum. We're glad you're here. When you get a chance, please [introduce yourself on this forum thread](https://forum.getodk.org/t/-/6671). I'd also encourage you to add a picture as your avatar because it helps build community!
for nested repeats your `indexed-repeat` function should be like this:
`indexed-repeat(${name_parcela}, ${repeat3}, 1, ${repeat2}, position(..))`
you need to define not only the number of the inner but also the number of the outer group.
The form would be like:
[trial.xlsx](https://forum.getodk.org/uploads/short-url/kM2oOnvOGbmBjMejvRFMSYldMbh.xlsx) (11.2 KB)
It works well in ODK Collect (you only need to remove the `field-list` appearance from groups that contain repeats because it's not supported) however in Enketo it doesn't work and the value from the first group is always displayed. @Sadiq_Khoja or @eyelidlessness maybe you are aware of this issue if it's reported or not at least?
