Hi everyone! I accidentally made a note required and now none of my forms will finalize or upload because it keeps saying its a required question.
ODK v1.15.0
I made a note a required question and now it won't let me finalize the surveys and upload. When I went to update the form it then told me that the existing form has been deleted.
I tried to replace the google drive xlsm file with a file with the same name and I tried to you the update version function both were not fruitful. Anything else we should know or have? If you have a test form or screenshots or logs, attach here.
If you did that properly you should be able to update that.
If not, another solution will be to check if submissions are still in the devices, ie submissions were not deleted after send. If available in all devices, you can delete the form, after changing the validation, then resubmit from odk collect.
I was able to upload a new version of my form (v 20200923) (with the same file name) and get the updated form on my device. However, when I open the form that I created with the old verison (v 20200901) and then saved because I wasn't able to finalize due to the required note, I see the note is still required and I can't finalize. Can you tell me what I'm doing wrong?
