I am currently running a fieldwork project in which we are collecting data in ODK. As each supervisor comes in from each day in the field they enter data about collected samples into a form and upload. At the same time they have to hand write a label, often many copies of the same label, to add to each sample bag that is identified by that form. I would love to add a button to generate a label (with QR code) using the "print" option so that they can print labels instead of writing them. I can see how to do this in the support docs. What I am having trouble with is figuring out which printers will actually be compatible with "send to a connected printer".
These need to be relatively robust labels, so regular direct thermal is no-good. I think it needs to be "thermal transfer" labels.
Are there any suggestions for a compatible thermal transfer printer that can be seen as a connected printer in android tablets so that we can directly print from the form? That would be amazing. I cant find any posts where anyone mentions a specific printer they have used recently (since the shift from the older Zebra-specific version) to do this, but it seems like something that should be needed by many people wanting to use this functionality!
I can see many options for thermal transfer printers but many of them only run through a dedicated app, not as a connected printer available to 3rd party apps like ODK collect. So I assume the other option is to save the print as a pdf on the tablet and then make sure the thermal-transfer printer app can open and print from a pdf. But that seems a bit more clunky, and the whole reason to add this functionality is that our supervisors are often pressed for time to finish the work for the day, and adding a printer is supposed to make the process less painful/time consuming!
Any recommendations would be greatly appreciated! Thanks and apologies if this was not the place to ask this!
Welcome, @Chad_Hill! This feels like a perfect question for the support category. Would love to learn more about you and your project in the community introductions thread when you get a chance!
I don't think anyone on the core team has tried label printers recently so hopefully someone from the broader community can chime in with specific model recommendations.
In the mean time, what you want to look for is evidence that a printer is compatible with the Android print system, not just the manufacturer's app.
I'd start by looking at manufacturers that have apps that make it possible to use printers with the Android standard print menu:
Zebra Print app
Print Service by Honeywell
Brother Print Service Plugin
TSC Print Service Plugin
If you can find printers that meet your specifications that work with these apps, you should be able to use them with Collect.
Approaching the problem from a different direction - would it be possible for you to preprint large numbers of QR plus text code labels?
Then the workflow becomes
fieldwork
return to base, review the day's collection, at the end of each submission, use a barcode question to scan a label, this ID goes to the submission and the label goes on the specimen
either the sheet has multiple copies of the same code, or you have a repeat in the form that scans as many unique codes as you need, depending on your sample count/ sample ID needs
affix label and verify
upload and knock off!
This won't allow you to have custom text on the label and so might not be appropriate. But if the code is the key identifier and a quick pen addition of a number etc is enough it may, and the labels can be printed on much more robust coated stock as well as not having to source and provide printers to your enumerators.
Yes, this was what I understood, that I needed printers that would work with the android print system, not just the manufacturer app, but I was finding it surprisingly hard to tell which ones do that! So your list is VERY helpful. Thank you!!
This is an excellent idea. But probably wont work for my application, unfortunately.
This is for an archaeological project (sorry, I was being unnecessarily vague in the original post, in an attempt to be brief!). Back when I was a grad student, I actually worked on an archaeological project that was doing pioneering digital data collection (over 20 years ago??? 2005?!) that did this exactly. All excavated artifacts, as they came out of the ground, were recorded spatially using a total station. The artifact went in a bag, and the bag got a preprinted barcode label that also got entered into the spatial record in the total station. It was an early "paperless" archaeology project and it was mind-blowing c.2005: we could see the 3d data in real time on laptops on site!!!
But there are a few reasons I dont think this can work in our current project. The most important one is that I absolutely want ALL of the critical context information to be on the bag. Supervisors write out by hand: site, unit, level, feature, date, sometimes coordinates, supervisor name, material type, etc on every bag. We do not want bags to be solely identified by a barcode, QR code, or single arbitrary number divorced from its archaeological context. This project is in a remote area, so we cannot always guarantee access to the database by everyone who might need to find something, or sort the material. If some material type goes to a specialist for analysis, I dont want them to be reliant on access to our ODK records to know what they are looking at and for the possibility to exist that the database could get separated from the material in the future and all of the context is lost!
Basically I don't want to rely solely on access to ODK central to be able to tell what is what, and if the supervisors are still writing the rest of the context info on the bag by hand, I think the printed barcode/qr code doesnt help much! But if I can concatenate the data they are already entering in their tablets at the end of the day (to do their end-of-day check in which has been working really well for us) to immediately print a label that includes all of that context info they are usually also writing out, and it can be on a legible and durable label, it would be awesome.
They sell laminated labels that are rated for outdoor use, though TBD to see how durable they are.
I was able to build into a web app a way to print QR codes directly to the printer via a USB connection, so maybe it'd be possible with some finagling for you to find a solution through the system?
