Hi all,
I installed the latest version of ODK Aggregate on a (Ubuntu)
VirtualBox machine and all appears to be running fine (in both the
host machine and the guest machine). However I´m having issues
downloading forms from this server when I run ODKCollect on the
Android emulator. Note that I´m running the emulator on the guest
machine - the same guest that ODK Aggregate server is running - not on
the host machine (though I did try this first).
In ODKCollect I enter the server url (http://192.168.56.101:8080/
ODKAggregate/) and username/password, then go to the manage form page.
ODKCollect connects to the Aggregate server fine and shows me a list
of the forms I have created - so far so good!
However, when I select the forms for download, I get the message that
the downloading of forms was successful (message: "Downloading Forms
Result, Alex test: SUCCESS"), but when I view the list of downloaded
forms nothing is displayed. I checked the Android log and it shows an
error:
"java.net.UnknownHostException: odkaggregate"
odkaggregate is the host name of my guest machine - so I realise that
I must have something wrong with my networking configuration in
VirtualBox, but I have a couple of questions:
- As I entered the server url as 192.168.56.101:8080... and this
connected fine, shouldn't then form downloader use this url rather
than 'odkaggregate'? I don´t quite understand where either ODKCollect
- or Aggregate is getting the url odkaggregate from (just from the
guest machine?)
- What url can I use in my guest machine browser to simulate
downloading the form - something like: http://192.168.56.101:8080/ODKAggregate/formdownloader?id=123
- I´d just like to know what the url is to download a form
- As the download was a failure, shouldn't the Downloading Forms
Results show an error rather than a success message? Is there
somewhere I should report this as a bug?
Sorry for the long message - any help much appreciated
Cheers,
Alex
hi alex,
can you file the download issue at
http://code.google.com/p/opendatakit/issues/list with the stack trace
attached? and if the information below helps, add it to the bug as
well..
i believe aggregate uses whatever fully qualified name you give it in
the installer as the root of whatever url. so try enabling the
anonymous user in aggregate. then if you connect to
http://192.168.56.101:8080/formList, it should give you the manifest
of files it would download. in that manifest, it should be something
like http://192.168.56.101:8080/formXML?formId=My_Form.
it may also be helpful connecting the emulator to 10.0.2.2:8080,
that's the ip the emulator sees as localhost, but i have no clue what
that will actually do on your setup...
yaw
On Wed, Jul 27, 2011 at 01:00, Alex Little wrote:
> Hi all,
> error:
> 1) As I entered the server url as 192.168.56.101:8080... and this
> guest machine?)
> 2) What url can I use in my guest machine browser to simulate
> 3) As the download was a failure, shouldn't the Downloading Forms
> Sorry for the long message - any help much appreciated :-)
> Cheers,
> Alex
Thanks for the quick reply Yaw. I've just submitted the issue with the
full stack trace (http://code.google.com/p/opendatakit/issues/detail?
id=273) Just let me know if any further info is needed here to
replicate (I realise it's possibly not a common configuration!- I
just prefer to trying out software on a virtual machine).
Thanks for the info about the URLs.
Is it possible to change the fully qualified domain name in Aggregate
now that it's already set up? I assume there's a setting for this
somewhere? I had a look in the ODKAggregate war file that was
produced, but I didn't see anything, I thought perhaps if I changed
this to the IP address I'd like to use then it may work?
Cheers,
Alex
On Jul 27, 11:10 am, Yaw Anokwa wrote:
> hi alex,
> can you file the download issue athttp://code.google.com/p/opendatakit/issues/listwith the stack trace
> well..
> anonymous user in aggregate. then if you connect tohttp://192.168.56.101:8080/formList, it should give you the manifest
> likehttp://192.168.56.101:8080/formXML?formId=My_Form.
> yaw
> > Hi all,
> > error:
> > guest machine?)
> > downloading the form - something like:http://192.168.56.101:8080/ODKAggregate/formdownloader?id=123
> > Cheers,
> > Alex
BTW... from the form list I can see it's giving the domain name I
entered at installation rather than the current address:
E.g. calling http://192.168.56.101:8080/ODKAggregate/formList gives
me:
Alex test
Alex test
If this list returned
Alex test
Alex test
then I think it will work.
Cheers,
Alex
> Cheers,
> Alex
> > hi alex,
> > can you file the download issue athttp://code.google.com/p/opendatakit/issues/listwiththe stack trace
> > well..
> > yaw
> > > Hi all,
> > > error:
> > > guest machine?)
> > > Cheers,
> > > Alex
I rebuilt the ODKAggregator war from the installer program (this time
using the IP instead of the machine name), now the forms are
successfully downloaded and I can go through the surveys in ODKCollect
in the emulator and view the data submitted in ODK Aggregate. Though
still interested to know if there's better way to change the domain
name/IP rather than rebuilding the whole war?
cheers,
A
> E.g. callinghttp://192.168.56.101:8080/ODKAggregate/formListgives
> me:
> Alex test
> Alex test
> Alex test
> Alex test
> Cheers,
> Alex
> > Cheers,
> > Alex
> > > hi alex,
> > > can you file the download issue athttp://code.google.com/p/opendatakit/issues/listwiththestack trace
> > > well..
> > > yaw
> > > > Hi all,
> > > > error:
> > > > guest machine?)
> > > > Cheers,
> > > > Alex
The installer takes your configuration information and builds:
WEB-INF/lib/ODKAggregate-settings.jar
Within that jar, the configurable settings are in:
jdbc.properties (for the datastore configuration)
security.properties (for the server name, ports and security configuration)
The xml files are selected based upon the deployment type (GAE, MySQL,
PostgreSQL).
The server name is coded into the configuration so that you can configure
Aggregate to construct URLs correctly if you are running behind a proxy
server, a load balancer, or using a CNAME.
cheers,
A
me:
Alex test
Alex test
Alex test
Alex test
Cheers,
Alex
Cheers,
Alex
On Jul 27, 11:10 am, Yaw Anokwa yano...@gmail.com wrote:
hi alex,
well..
yaw
On Wed, Jul 27, 2011 at 01:00, Alex Little a...@alexlittle.net wrote:
Hi all,
on
page.
list
that
Forms
downloaded
an
error:
that
ODKCollect
guest machine?)
Cheers,
Alex
http://www.OpenDataKit.org
we've had a number of issues where people don't understand what the
hostname is used for. we will add some some text to the installer that
explains that the hostname is the ip that the phone and browser will
use to connect to aggregate. or something like that
http://code.google.com/p/opendatakit/issues/detail?id=277
> PostgreSQL).
> Mitch
>> cheers,
>> A
>> > me:
>> > Alex test
>> > Alex test
>> > Alex test
>> > Alex test
>> > Cheers,
>> > Alex
>> > > Cheers,
>> > > Alex
>> > > > hi alex,
>> > > > well..
>> > > > in
>> > > > what
>> > > > yaw
>> > > > > Hi all,
>> > > > > not on
>> > > > > page.
>> > > > > list
>> > > > > that
>> > > > > Forms
>> > > > > downloaded
>> > > > > an
>> > > > > error:
>> > > > > that
>> > > > > ODKCollect
>> > > > > guest machine?)
>> > > > > Cheers,
>> > > > > Alex
> Mitch Sundt
> Software Engineer
Thanks for the info Mitch,
Editing the properties file will be easier than rebuilding the whole
war - though I guess I shouldn't need to be doing it too often (it's
just while I'm playing around!)
Cheers,
Alex
> PostgreSQL).
> Mitch
> > cheers,
> > A
> > > me:
> > > Alex test
> > > Alex test
> > > Alex test
> > > Alex test
> > > Cheers,
> > > Alex
> > > > Cheers,
> > > > Alex
> > > > > hi alex,
> > > > > well..
> > > > > yaw
> > > > > > Hi all,
> > on
> > page.
> > list
> > that
> > Forms
> > downloaded
> > an
> > > > > > error:
> > that
> > ODKCollect
> > > > > > guest machine?)
> > > > > > Cheers,
> > > > > > Alex
> Mitch Sundt
> Software Engineerhttp://www.OpenDataKit.org
> mitchellsu...@gmail.com
