Hello ODK Community,
I hope you guys are well.
I want to creat the following data input mask in ODK. What would be the
best to codify it using Excel (and ONA). I have 21 indicators and for each
indicator I have the same variables.
Many thanks
uh
Declared quantity Verified Quantity Validated Quantity Difference Difference
in% … Vaccination CPN CPoN Consultation <5 ans
Indicator 21
Hi Ulises,
You can pick an indicator and ask the 4 questions or pick a question
and ask it about all 21 indicators.
What I usually do for these sorts of forms is pick the indicator and
ask the 4 questions. I group each indicator into a field-list with a
note for the label, then the questions I want to ask. In this case,
you can probably skip difference questions since you can calculate
that after the fact.
Do this for two indicators and see if the form and the resulting CSV
work for you, then go from there.
Need ODK consultants? https://nafundi.com provides form design, server
setup, in-field training, and software development for ODK.
On Tue, Oct 6, 2015 at 9:54 PM, Ulises HM ulises.huerta.munoz@gmail.com wrote:
I want to creat the following data input mask in ODK. What would be the best
Many thanks
uh
in% …
Vaccination
CPN
CPoN
Consultation <5 ans
Indicator 21
