I can see that in the 1.4.4 update of Collect a saveincomplete() option was
added into ODK by Nafundi (thanks again Nafundi!).
Anyone know how to use this function in XLSform format? I'd like to save as
far as a user gets on a self-taken survey even if they exit the form early
(I.E. put a saveincomplete() on every question). Is the syntax supported in
XLSforms yet (can I add saveincomplete as a column label in the excel
survey form design, and add TRUE for every question?) or do I need to do
this some other way?
On Tuesday, January 12, 2016 at 12:19:54 PM UTC+8, Neal Barsch wrote:
> Hi all,
> I can see that in the 1.4.4 update of Collect a saveincomplete() option was added into ODK by Nafundi (thanks again Nafundi!).
> Anyone know how to use this function in XLSform format? I'd like to save as far as a user gets on a self-taken survey even if they exit the form early (I.E. put a saveincomplete() on every question). Is the syntax supported in XLSforms yet (can I add saveincomplete as a column label in the excel survey form design, and add TRUE for every question?) or do I need to do this some other way?
> Thanks for your help!
> Neal
