Sorry that I cannot give you a 100% definitive answer, but it looks like
the SD card requirement is no longer valid.
Despite having only 2GB left on my phone's memory, ODK Collect
'installed itself' on my phone's memory (not the SD card).
I use a phone with a SD card and plenty of space on it, and ODK runs
from the build-in memory.
My phone runs on Android 6 and ODK Collect runs without any problems.
According to the link below, ODK Collect works fine on a OnePlus One
phone (without SD card)
On Tuesday, December 6, 2016 at 5:52:38 AM UTC+10, Calum Handforth wrote:
> Hi all,
> I'm looking to invest in a OnePlus phone and it has no external SD card.
> Will ODK still function, perhaps mapped to a different directory, or not?
> Thanks,
> Calum
"There must be an external SDCard on the device. Most Android 4.x devices
have one of these built-in. Older Android 2.x devices generally do not and
require that one be installed (typically in a slot near your SIM card). If
ODK Collect fails to start, it is likely because the SDCard has become
unseated or is missing. Re-seat or install the SDCard and try again."
The OnePlus version of Android is higher than 4 so you should be able to
install ODK without an SD Card.
Sam
On Monday, 5 December 2016 21:52:38 UTC+2, Calum Handforth wrote:
> Hi all,
> Thanks,
> Calum
OnePlus Three user here. No issues with loading and running ODK on the
device!
On Tuesday, 6 December 2016 01:22:38 UTC+5:30, Calum Handforth wrote:
> Hi all,
> Thanks,
> Calum
Thanks for the quick reply, and the promising answer! Have you tried
opening/running ODK without the SD card installed at all?
Calum
On Tuesday, December 6, 2016 at 1:38:43 AM UTC, Robby wrote:
> Hi Calum,
> - Despite having only 2GB left on my phone's memory, ODK Collect
> - According to the link below, ODK Collect works fine on a OnePlus One
> http://support.kobotoolbox.org/customer/portal/questions/11455743-record-location-kobocollect
> Good Luck!
> Rob
>> Hi all,
>> Thanks,
>> Calum
ODK Collect saves to whatever directory the device reports when we
call getExternalStorageDirectory(). On older Android devices, that is
the removable SD card (which is why the ODK website says that). On
newer devices, it's the internal storage. On some Samsung devices,
it's a folder on the internal SD card.
If your phone has no SD card slot, ODK should work just fine. It'll
save to internal memory.
On Thu, Dec 8, 2016 at 9:26 AM, Sam Phiri wrote:
> Hi Calum,
> See here for a response to this. The ODK website says:
> Sam
>> Hi all,
>> Thanks,
>> Calum
> "ODK Community" group.
Thanks for bumping this (and for confirming), I'd forgotten about this
topic. I've now bought my OnePlus 3T (highly recommended) and can also
confirm that there's no issues with ODK.
Calum
On Tuesday, January 3, 2017 at 11:04:00 AM UTC, Anubhav Vanamamalai wrote:
> Hello,
> device!
>> Hi all,
>> Thanks,
>> Calum
Thanks for confirming this. I was a little confused as the OnePlus doesn't
have an internal SD card as part of its memory, but glad to hear it'll work
alright.
Calum
On Thursday, December 8, 2016 at 2:38:29 PM UTC, Yaw Anokwa wrote:
> Calum,
> Yaw
> On Thu, Dec 8, 2016 at 9:26 AM, Sam Phiri <mitow...@gmail.com > wrote:
> > Hi Calum,
> devices
> and
> If
> > Sam
> >> Hi all,
> card.
> not?
> >> Thanks,
> >> Calum
> Groups
> an
Just confirming it does work with phones without the SD card. I am a
developer with a nexus 6p and Android 7.1.1 and it works just fine - this
is given the fact that the Nexus 6p does not have external storage
capability. Adobe person said in this email thread, it just finds its path
and create an ODK directory of its own.
doesn't have an internal SD card as part of its memory, but glad to hear
it'll work alright.
Calum
Calum,
devices
and
If
to
Sam
Hi all,
card.
not?
Groups
an
> sent from my Samsung Tablet
> On Dec 8, 2016 7:09 PM, "Calum Handforth" <calum.h...@gmail.com > wrote:
>> Hi all,
>> it'll work alright.
>> Calum
>>> Calum,
>>> Yaw
>>> > Hi Calum,
>>> devices
>>> and
>>> card). If
>>> to
>>> > Sam
>>> >> Hi all,
>>> card.
>>> not?
>>> >> Thanks,
>>> >> Calum
>>> Groups
>>> an
