Select_multiple urgent help
Hi Guys,
I am quite new in using xls forms, and I have suddenly got a stopper.. Que.
This is a small scale farmer survey.. in case you have a select_multiple
que of a farmer who 1. Grows crops 2. Keeps livestock 3. Does poutry. and
now you want to go to the sections of those who choose *Grow crops, *how
will you do this?.
Hi Stanley,
ODK does not support the concept of "going somewhere" or "skips" instead it
uses "relevant".
Hence you can put your questions about growing crops into a group and in
the "relevant" column for that group you could add:
selected(${crops_question_name}, 'grows_crops')
The first parameter in the selected function is the name of the question
that asked what crops are grown surrounded by ${ }. The second parameter
is the value of the choice if they select the growing crops choice. This
has to be surrounded by single quotes.
The group will then be shown if they selected the growing crops choice.
regards
Neil
ยทยทยท On Sat, Dec 24, 2016 at 6:09 AM, Stanley Nyoro wrote:
Hi Guys,
Que. This is a small scale farmer survey.. in case you have a
select_multiple que of a farmer who 1. Grows crops 2. Keeps livestock 3.
Does poutry. and now you want to go to the sections of those who choose *Grow
crops, *how will you do this?.
Smap Consulting http://smap.com.au/| Mobile Data Collection Solutions
Application Developer - neilpenman@gmail.com minqiang.huang@gmail.com
Twitter: @dgmsot
Skype: ianaf4you
Phone: +61 402 975 959
Website: http://smap.com.au http://smap.com.au/blog
