I managed to set up ODK collect in eclipse and everything is working great.
However, it took a fair number of steps to do so. I have someone with very
little experience that needs to get ODK collect running on the emulator. Is
there a step-by-step guide that can tell her how to do this? If not, there
really should be. I'd be willing to write something up that can be put on
the wiki (though I really hope I don't have to ).
we currently don't have any instructions on how to get started with
odk collect (android, mercurial, etc) in eclipse and we'd love your
help generating those! you can probably get some of the other devs on http://groups.google.com/group/opendatakit-developers to chip in.
what you are describing for implementers is a little different -- you
shouldn't need eclipse and all that stuff. i think we have rough
outline at http://code.google.com/p/opendatakit/wiki/ODKCollect. that
is, install the emulator, create an sd card, and then install collect
from web. are you proposing more detailed instructions to get
implementers into using collect?
路路路
On Tue, May 25, 2010 at 13:02, Anton de Winter wrote:
> Hi,
> the wiki (though I really hope I don't have to ;) ).
> Thoughts?
> Cheers,
> Anton
So you can't actually, legally anyway, access the market from the emulator
(in 1.5/1.6). Which means you have to get your Eclipse on.
Unless you've found a way around it? The outline you mention only covers
downloading the app onto your real phone and usage instructions once you've
done that.
路路路
great.
very
Is
there
on
Thoughts?
Cheers,
Anton
you can open the browser in the emulator then navigate to the odk
website and download the apk from there. this assumes you have install
from non-market source setting enabled.
路路路
> done that.
>> > Hi,
>> > great.
>> > very
>> > Is
>> > there
>> > on
>> > Thoughts?
>> > Cheers,
>> > Anton
路路路
emulator
you've
done that.
great.
with
very
emulator.
Is
there
put
on
Thoughts?
Cheers,
Anton
I've written some instructions (attached). I don't have edit-powers to the
wiki, so feel free to add them to the existing ODK getting started page if
they pass muster.
路路路
On Tue, May 25, 2010 at 6:19 PM, Anton de Winter wrote:
Ah that's awesome. It's exactly what I needed.
Thanks!
Anton
emulator
you've
done that.
great.
with
very
emulator.
Is
there
put
on
Thoughts?
Cheers,
Anton
Hello. Does anyone know if there is a version of android that allows people to restrict functionality by user? I am interested in using the phone more as an appliance limiting it's use to ONLY ODK (with the option of switching back to normal functionality with a password).
I remember the Berkeley Team had simply put it in airplane mode and tried to remove all applications from the desktop but ideally there would be a better solution to limiting access to other phone functions.
you can build a version of android that limits much of the core
functionality, but that's a fair amount of work. if you want existing
solutions, i found a few using a 'hide apps in drawer android' query.
try 'em out and let the other implementers know which worked best...
all that said, i tend to prefer to manage this problem with a lighter
touch. that is, locking down the browser, or sms app might have
unintended consequences. the more the users play with the phone, the
better they are at touchscreens, and swapping batteries, and making
sure the phone isn't dropped, and all the stuff that you are training
for...
路路路
> Thanks for your help,
> Andrew
thanks for getting this written up. i've updated the collect wiki to
point to http://code.google.com/p/opendatakit/wiki/DevelopmentEnvironment
and added other dev tips. i've also cleaned up the instructions so
they are more resilient to future changes from our friends at google.
yaw
路路路
> they pass muster.
> -Anton
>> Thanks!
>> Anton
>>> > emulator
>>> > covers
>>> > you've
>>> > done that.
>>> >> > Hi,
>>> >> > great.
>>> >> > with
>>> >> > very
>>> >> > emulator.
>>> >> > Is
>>> >> > not,
>>> >> > there
>>> >> > put
>>> >> > on
>>> >> > Thoughts?
>>> >> > Cheers,
>>> >> > Anton
