Hi All
I would like to set a relevance using xlsform to a note if an answer to a
previous question is within a range of values.
I.E. would like to show a note of a persons cholesterol level is between:
below 5.2 > show note A
between 5.2 and 6.2 > show note b
above 6.2 > show note C
Bashir Jahed - Director
The OSi LAB (PTY) Ltd
www.osilab.net | 083 414 0453 | bashir@osilab.net
Hi Bashir,
See http://opendatakit.org/help/form-design/xlsform (Skipping
Questions) or https://formhub.org/syntax (3.3 Asking Relevant
Questions).
On Mon, Jun 3, 2013 at 4:41 AM, Bashir Jahed admin@osilab.net wrote:
Hi All
I would like to set a relevance using xlsform to a note if an answer to a previous question is within a range of values.
Thanks Yaw
I am familiar with skipping and asking relevent questions however
displaying a question/note on a value is what I am trying to achieve, I
only want to display a note of the answer given is between a range of 5.2
and 6.2 inclusive.
I am able to display note A using ${cholesterol} < 5.2 but I am trying to
display note B if the answer is ${cholesterol} = (between 5.2 & 6.2) or am
i missing something from the links you sent?
On Mon, Jun 3, 2013 at 8:35 PM, Yaw Anokwa wrote:
Hi Bashir,
Questions).
Hi All
Bashir,
You can use a relevance expression like:
${cholesterol} >= 5.2 and ${cholesterol} <= 6.2
Chris
On Tue, Jun 4, 2013 at 10:16 AM, Bashir Jahed wrote:
Thanks Yaw
and 6.2 inclusive.
am i missing something from the links you sent?
On Mon, Jun 3, 2013 at 8:35 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi Bashir,
Questions).
Hi All
between:
Ah that simple, porridge brain moment.
Thanks Robert I will try this out and feed back.
Bashir
On Tue, Jun 4, 2013 at 10:27 AM, Christopher Robert wrote:
Bashir,
Chris
On Tue, Jun 4, 2013 at 10:16 AM, Bashir Jahed admin@osilab.net wrote:
Thanks Yaw
and 6.2 inclusive.
to display note B if the answer is ${cholesterol} = (between 5.2 & 6.2)
or am i missing something from the links you sent?
Hi Bashir,
Questions).
Hi All
between:
