Ok so now I have uploaded my form to form hub,set up a google app and run
ODK on my computer...now what. All these things are set up seperately, but
how do I get the form to load on to the app? Any help would be great.
Check out the very informative website, for instance herehttp://opendatakit.org/use/collect/.
I follow the instruction toward the bottom of that page:
Forms you design do not have to be uploaded to Aggregate for them to be
> used. They can be manually added to the device. Simply place them in the
> /odk/forms folder on your Android device's SD card.
Yeah I'v ebeen using the ODK steps to figure things out. However I am not
in country so loading the survey manually is not really an option.
Since we have the aggreate set up now and the forms on formhub do you know
how to create an ODK account. The next step says that we should log into
ODK and change the settings but I the google app account information doesnt
seem to be working. Any suggestions would be great.
AJB
Formhub and ODK Aggregate are two different back-end solutions. Both
host forms for download to client devices and both collect submitted
data. Formhub is a managed server. ODK Aggregate provides you with
the code to set up your own cloud server that only you control. They
are not setup to communicate with each other. Therefore, first you
need to decide which you'll be using.
If ODK Aggregate, then you will need to set up accounts (with
different privileges), upload forms (put together with Build or
XLSform), point client devices to that server so they can download the
forms.
Gaetano
On Fri, Oct 19, 2012 at 6:24 AM, AJ RSPH wrote:
> Yeah I'v ebeen using the ODK steps to figure things out. However I am not in
> how to create an ODK account. The next step says that we should log into ODK
> and change the settings but I the google app account information doesnt seem
> Thanks,
> AJB
>>> Check out the very informative website, for instance here. I follow the
>>> Hi,
>>> Thanks
>>> #neverprogramedanythinginmylifenotevenamicrowave
On Saturday, October 20, 2012, Gaetano Borriello wrote:
Just to clarify .....
forms.
not in
know
ODK
seem
AJB
the
the
run
but
