Dear friends
I am trying to set up the ODK software and would be grateful for some
assistance.
Specifically, I need help in linking the "Build" interface to the
"Aggregate" interface.
When I try to publish a form to Aggregate, I am prompted for an Aggregate
instance url (http://___________ .appspot.com).
I have registered a a cloud database in the Google Developers Console.
My question is what should the Aggregate Instance url be?
(http://??????????????????.appspot.com).
On a related note, when I save a completed form, where does the form save
to? Does it automatically save to my Google cloud?
Regards
Brad
Build publishing into ODK Aggregate should no longer work. Google disabled
or should be disabling the mechanism.
From Build, you must "Export to XML..."
then log onto ODK Aggregate,
go to the Forms Management page, and
choose "Add New Form..."
On Mon, Jan 4, 2016 at 11:52 PM, Brad Aigner wrote:
Dear friends
assistance.
My question is what should the Aggregate Instance url be? (http://
Regards
Brad
