If I want to share a form I'm creating in Build with another user...
is there a way to do this? I don't see any option for importing
xforms... or sharing build files, etc.?
It would be great to have a way for multiple users to collaborate on
the same build form.
Matt
Hi Matt:
Not at the moment. Just to get a feeling for what you're looking for here, would it suffice to add the ability to save and load .odkbuild native files and email them around, or would it be better if it were something built into the application itself?
—Clint
Matt
saving and loading .odkbuild native files would get the job done -
sounds great!
Matt
On Feb 22, 2:51 pm, Clint Tseng wrote:
> Hi Matt:
> Thanks,
> —Clint
> > Matt
Dear Clint,
adding the tool to load .odkbuild native files will be great. We are
collaborating with others in different countries where the forms need
to be tweaked slightly. would this feature take long to have?
thanks
Seb
On Feb 22, 7:51 pm, Clint Tseng wrote:
> Hi Matt:
> Thanks,
> —Clint
> > If I want toshareaformI'm creating inBuildwith another user...
> > xforms... or sharingbuildfiles, etc.?
> > the samebuildform.
> > Matt
If you need a temporary workaround you might be able to use Dimagi's
(extremely alpha) FormDesigner[1] to do what you need.
We are actively fixing a number of known issues, but it should work
for import/edit/export of simple forms.
When you open this link click "login as guest user" and it will
redirect you to the form designer.
Cory
[1] http://build.dimagi.com:250/repository/download/bt32/9136:id/designer/FormDesigner.html
On Wed, Mar 9, 2011 at 5:18 AM, Seb (Mali) wrote:
> Dear Clint,
> thanks
> Seb
>> Hi Matt:
>> Thanks,
>> —Clint
>> > the samebuildform.
>> > Matt
