Showing Output on a Form
Dear Sirs et Madames,
I have a form with multiple prompts on a single screen where I would
like the question "What was the source of your information?" to appear
at the top. My attempt at doing this is shown below:
                              <group ref="/sero-survey1/groupHIV/
groupSourceOfHIVInformation" appearance="field-list" >
                                                    <output
value="What was the source of your information?"/>
						<input ref="/sero-survey1/groupHIV/groupSourceOfHIVInformation/
radio" >
Radio
Television/Video/Cinema
Posters
However that does not work, nothing is ever output, and am not sure
what my options are if I need to display just plain text on a screen?
Any suggestions?
Thanks in advance,
Tumaini
use a normal string prompt, but set the bind so it is read only.
output only works to reference data in a value.
my answer was
examples of things like this are at
http://opendatakit.org/help/form-design/ and
http://code.google.com/p/opendatakit/source/browse?repo=forms
··· On Sat, Nov 26, 2011 at 08:03, Tumaini Kilimba wrote: > Dear Sirs et Madames, > I have a form with multiple prompts on a single screen where I would > like the question "What was the source of your information?" to appear > at the top. My attempt at doing this is shown below: > > > > value="What was the source of your information?"/> > > > Radio > > > Television/Video/Cinema > > > Posters > > > > However that does not work, nothing is ever output, and am not sure > what my options are if I need to display just plain text on a screen? > Any suggestions? > > Thanks in advance, > Tumaini > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >
Hello Yaw,
I notice that using this method creates empty columns in the postgres
database, is this normal or am I doing it wrong?
Tumaini
··· On Sunday, November 27, 2011 4:15:43 AM UTC+3, Yaw Anokwa wrote: > > use a normal string prompt, but set the bind so it is read only. > > > output only works to reference data in a value. > my answer was > > examples of things like this are at > http://opendatakit.org/help/form-design/ and > http://code.google.com/p/opendatakit/source/browse?repo=forms > > On Sat, Nov 26, 2011 at 08:03, Tumaini Kilimba wrote: > > Dear Sirs et Madames, > > I have a form with multiple prompts on a single screen where I would > > like the question "What was the source of your information?" to appear > > at the top. My attempt at doing this is shown below: > > > > > > > > > value="What was the source of your information?"/> > > > > ref="/sero-survey1/groupHIV/groupSourceOfHIVInformation/ > > radio" > > > > Radio > > > > ref="/sero-survey1/groupHIV/groupSourceOfHIVInformation/ > > tv" > > > > Television/Video/Cinema > > > > ref="/sero-survey1/groupHIV/groupSourceOfHIVInformation/ > > posters" > > > > Posters > > > > > > > > However that does not work, nothing is ever output, and am not sure > > what my options are if I need to display just plain text on a screen? > > Any suggestions? > > > > Thanks in advance, > > Tumaini > > > > -- > > Post: opendatakit@googlegroups.com > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > >
Unfortunately, this is expected. The entire form instance is transmitted
to the server, so these intermediate fields are sent in addition to all
your meaningful data fields, and all are stored on the server.
One goal of ODK 2.0 will be to separate the working "scratch" data from the
data actually transmitted to the server so that everyone has more
flexibility in the presentation of the form screens and questions.
··· On Thu, Jun 14, 2012 at 10:02 AM, Tumaini Kilimba wrote:
Hello Yaw,
Tumaini
my answer was
http://opendatakit.org/help/**form-design/http://opendatakit.org/help/form-design/and
http://code.google.com/p/**opendatakit/source/browse?**repo=formshttp://code.google.com/p/opendatakit/source/browse?repo=forms
                                                   <output
                                                   <input
ref="/sero-survey1/groupHIV/**groupSourceOfHIVInformation/
radio" >
Radio
                                                   </input>
                                                   <input
tv" >
Television/Video/**Cinema
                                                   </input>
                                                   <input
posters" >
Posters
                                                   </input>
                              </group>
Any suggestions?
Thanks in advance,
Tumaini
Unsubscribe: opendatakit+unsubscribe@**googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
