Hi there,
A simple easy suggestion to add to the ODK bindings is an absolute value function. Since error margins are commonly used to calculate checks, this would make things easier.
Lu
Hi there,
Lu
Dear Lu,
Have you taken a look at the xpath functions pagehttp://www.w3schools.com/xpath/xpath_functions.asp?
I think there there is an absolute value function there that should work
with Xlsforms. I haven't used it myself but you can give it a shot (I know
that the "not" function works, and if I am not wrong, xlsforms uses xpath
so the abs() function should work too).
Warm Regards
Adeeb
I'm pretty sure JavaROSA doesn't have abs() support. I've filed the
feature request at
https://code.google.com/p/opendatakit/issues/detail?id=998.
Best way to guarantee this happens is for you to code it and submit a
patch. It's very straight-forward.
On Mon, May 5, 2014 at 9:01 AM, Adeeb Choudhury adeeb.choudhury@gmail.com wrote:
Dear Lu,
Have you taken a look at the xpath functions page? I think there there is an
absolute value function there that should work with Xlsforms. I haven't used
it myself but you can give it a shot (I know that the "not" function works,
and if I am not wrong, xlsforms uses xpath so the abs() function should work
too).Warm Regards
AdeebOn Monday, 5 May 2014 16:18:41 UTC+6, tcluc...@gmail.com wrote:
Hi there,
would make things easier.Best,
Lu
