We are trying to collect some general data about the soil in specific locations that are provided to us. As our researchers indicated that buildin GPS sensor can not be used as an option. We are hoping to get a single read from the Bluetooth dongle for each location.
I have already created a XForm and uploaded to ODK Aggregate.
I know that partially a code has to be written, where do I write it and how?
Hi Yaw,
I have disabled location services of the phone through settings.
Then I connected to Bluetooth device, even if the application ( https://play.google.com/store/apps/details?id=googoo.android.btgps&hl=en )
was able to retrieve data, ODK gave an error claiming location services are
disabled.
Regards,
Melissa
On Friday, February 14, 2014 10:47:09 PM UTC+2, Yaw Anokwa wrote:
> Melissa,
> It's not clear to me that code has to be written. First, make sure the
> bluetooth GPS can pair with your phone. Then use this app
> (or something similar). Then when you go to record location, I believe
> it will grab it from the Bluetooth GPS.
> Yaw
> Need ODK services? http://nafundi.com provides form design, server
> setup, professional support, and software development for ODK.
> On Thu, Feb 13, 2014 at 3:40 AM, <melissac...@gmail.com > wrote:
> > Hi,
> how?
> > Regards,
> > Melissa
> Groups "ODK Developers" group.
> an email to opendatakit-developers+unsubscribe@googlegroups.com.
> > For more options, visit https://groups.google.com/groups/opt_out.
bluetooth GPS can pair with your phone. Then use this app https://play.google.com/store/apps/details?id=googoo.android.btgps&hl=en
Hi Yaw,
(https://play.google.com/store/apps/details?id=googoo.android.btgps&hl=en )
disabled.
Regards,
Melissa
Melissa,
how?
Hey,
Thanks I have found one that works for my cause.
Great help!
Melissa
On Monday, February 17, 2014 10:41:13 PM UTC+2, Yaw Anokwa wrote:
> Pretty sure you need location services on for any location services to
> work. Try turning it back on and see if something like
> https://play.google.com/store/apps/details?id=com.eclipsim.gpsstatus2
> works with Bluetooth.
> Yaw
> On Mon, Feb 17, 2014 at 5:07 AM, melissa colakoglu <melissac...@gmail.com > wrote:
> > Hi Yaw,
> https://play.google.com/store/apps/details?id=googoo.android.btgps&hl=en)
> are
> > disabled.
> > Regards,
> > Melissa
> >> Melissa,
> >> Yaw
> >> On Thu, Feb 13, 2014 at 3:40 AM, wrote:
> >> > Hi,
> buildin
> single read
> and
> >> > how?
> >> > Regards,
> >> > Melissa
> send
> Groups
> an
