I am trying to add skip patterns to a form that I have created in
Build. Most of my skip patterns are working just fine because they are
based on one statement (e.g. /data/Q1=1). However, I am having trouble
with the skip pattern when I need to use 2 statements (e.g. /data/
Q2>=11 or /data/Q2<=18) What is wrong with the second relevance
statement? I have tried /data/Q2>=11 or Q2<=18 and that didn't work. I
have also tried:
/data/Q2>=11 or <=18
/data/Q2>=11or/data/Q2<=18
Neither of these worked. Similarly, I am trying to build a skip into
my form that involves 2 different questions (e.g. /data/Q6!=''0' and /
data/Q18>0) This has not worked either. Please let me know how I can
fix them.
You need to specify the left and right sides for each comparison. e.g.,
/data/Q2 >= 11 or /data/Q1 <= 8
have also tried:
fix them.
please i used the odk build to develop a form now i have two different(Sector_Information1 and Sector_Information1 )groups. before these groups show with Sector_Information coming first n the next swipe Sector_Information1 comes.
i have a (choose one) check-box which i want to choose one sector(Agriculture, Education or Energy) so either Sector_Information or Sector_Information1 only shows.
have also tried:
fix them.
You will have to use relevance to do this branching. I'd recommend you
switch to XLSForm because it'll be easier to do the form building
there. See http://xlsform.org/#relevant for more.
It might also be the <> symbols causing the problem. You might need to
replace them with xml entities. By that I mean instead of writing < write
< and instead of > write >
Regards,
-Nathan
On Fri, Apr 27, 2012 at 12:53 PM, Prabhas Pokharel < prabhas.pokharel@gmail.com> wrote:
I also generally find better luck if I use parentheses, ie, something like
(/data/Q2 >= 11) or (/data/Q1 <= 8)
have also tried:
fix them.
When within ODK Build you do not have to; it will do the replacement for you. Makes writing logic quite a bit less frustrating.
-Clint
On Friday, April 27, 2012 at 1:28 PM, Nathan Breit wrote:
It might also be the <> symbols causing the problem. You might need to replace them with xml entities. By that I mean instead of writing < write < and instead of > write >
Regards,
-Nathan
have also tried:
fix them.
Clint, in the final output, it does have to be > instead of > , right?
The Xform will choke in < or >, is that correct?
☞§※☼:airplane:
~Neil
I have achieved the relevant function but now i need the next question to load right after the select one (answer is choose)all on the same page. On mine current form i need to swipe to the next page n return back before it loads the next relevant questions for me.
Want i want is for the next question to load right after the fist question is chosen on the same page
That is definitely correct. ODK Build automatically encodes all input you give it as appropriate (and tries to avoid double-encoding, so if you do put > or & into it, it'll leave it alone), but otherwise the XML is considered malformed.
-Clint
