I want an alternative to this type of coding( ${4rw}=1, or ${gdd}=2, or ${jff}=3). I want a shorter code that will just give the range form 1 to 3
ODK Collect v1.8.1 What steps can we take to reproduce the problem?
You can use make a group with begin group-end group. And if you can give your form if you don't mind than this will be more helpful for us to resolve your problem.
There was some discussion around adding a convenience function like this at the XLSForm level a while ago here. Expressing interest there and providing feedback on how the function should be structured would be helpful.
