I'm new with ODK and trying to design a form using ODK build; and the
command for skip pattern/relevance and calculations seems to be giving me
errors. Can someone assist me with a link which has workable examples of
the syntax or command.
Best
On Thu, Jan 21, 2016 at 8:05 PM, wrote:
Hi All,
Please go through the requirements and share updated resume and details
ASAP
Position: UI Developer
Duration: 6+Months
Need local for In-Person Interview.
Mandatory Skills
Expert in HTML5/CSS3/JavaScript
Solid JavaScript concepts with experience in writing code in Object
oriented way
Experience with JQuery, Underscore or similar libraries
Experience working with AngularJs, Backbone, CanJs or similar MVC
frameworks
Experience working with SpringMVC based or similar application code-base
Experience working with source controlled code base like git or svn
Thanks & Regards
Sourav Paul | Technical Recruiter
*IT–SCIENT LLC, Fremont, CA, USA *
*Email: *sourav982.itscient@gmail.com sourav982.itscient@gmail.com
Phone: 510-972-5240 | Fax: 877-701-4872 <877-701-4872>
*|web: *www.itscient.com http://www.itscient.com/
Donald Odhiambo
P.O Box 51060-00100, Nairobi, Kenya
Cell: +254-727-705-052 | +254-731-705-052
Emails: donald@tecttona.com | infodonaldo@gmail.com
There is some documentation here: http://xlsform.org/
and also here: https://opendatakit.org/help/form-design/binding/ -- though
the "Example" syntax on this page is for the XML file generated by XLSForm,
not the source XLS.
The big difference w.r.t. XLS syntax is that you can use ${fieldname} to
refer to your data field rather than know the full XPath (e.g.,
/data/group/nestedgroup/fieldname) expression to reference the fieldname.
This is especially useful as it is very common to wrap questions in begin
group ... end group in order to apply relevance conditions to a set of
questions.
There are a few formulas in the XLSForm example XLS file here:
And there are a few more example XML forms here
https://github.com/opendatakit/sample-forms -- unfortunately, many of these
were developed before the community invented XLSForm, so there are no XLS
files for these.
Best
On Thu, Jan 21, 2016 at 8:05 PM, sourav982.itscient@gmail.com wrote:
Hi All,
ASAP
Duration: 6+Months
Mandatory Skills
oriented way
frameworks
Thanks & Regards
Phone: 510-972-5240 <510-972-5240> | Fax: 877-701-4872 <877-701-4872>
Donald Odhiambo
