Skip question using xls
How do we skip skip suedtion
ODK Aggregate v1.4.15
Can you please give me an example of logic
QQ_1f.xls (64 KB)
Hello Iqbal,
If I want to skip 5 questions all at once how do we skip it ??
Hello @sanish_shrestha ,
You can keep all the 5 questions in a begin group and in the row of begin group under relevant header , add the relevant condition which will either skip or show all the 5 questions . Hope that helps.
Thanks and Regards,
SGSC
make a group five question just simple
