Dear All,
How do i make skiplogic adjust with numbers when developing xls forms
Example 1. Do you live in Nigeria
2. How many states are in Nigeria
3. Respondent Phone Number
How do i make sure that if the response to question 1 is NO then question 3 becomes question 2 on ODK
You cannot change question number but can skip question https://docs.opendatakit.org/form-logic/#conditionally-showing-questions.
You can accomplish something equivalent by modifying the question label text dynamically in response to previous answers. Its a bit messy, but if you only have a handful of questions it may suffice. Try this:
renumber.xls (5.5 KB)
which will appear as:
