2. You can include one or more static choice options, in addition to the
dynamic ones loaded from your .csv file. Simply include static choices, as
you normally would, on the choices worksheet. These can appear before
and/or after the row that indicates the columns to use for your dynamic
choices. The one restriction is that the values you specify for your static
choices in the name column must be numeric.
Have you downloaded the sample forms on that page, and tried to to
include static options? If so, let the list know what specific problem
you ran into. If no, try doing that first.
Need ODK consultants? https://nafundi.com provides form design, server
setup, in-field training, and software development for ODK.
you normally would, on the choices worksheet. These can appear before and/or
after the row that indicates the columns to use for your dynamic choices.
The one restriction is that the values you specify for your static choices
On Thursday, November 5, 2015 at 3:11:17 AM UTC+3, Yaw Anokwa wrote:
> Hi there,
> Thanks,
> Yaw
> On Wed, Nov 4, 2015 at 8:18 PM, geoenginfo wrote:
> > Hello
> > Can someone guide me how to implement static choice option (in addition to
> > dynamic one generated from pre-loaded data) , as mentioned on this page -
> > http://opendatakit.org/help/form-design/data-preloading/
> > The last paragraph:
> > You received this message because you are subscribed to the Google Groups
> > "ODK Community" group.
> > To unsubscribe from this group and stop receiving emails from it, send an
> > email to opendatakit+unsubscribe@googlegroups.com.
