Step by step of opening ODK Collect in Android Studio
No I am not able to resolve it I am asking the question from last two
weeks and I am also trying to find but unable to get any solution if you
get any solution then please mail me
··· On Wed, Jun 29, 2016 at 7:54 PM, Achyut Bhandiwad wrote:
I am facing the same error as you. Did you resolve it?
Thank you
On Sunday, 19 June 2016 22:38:34 UTC+5:30, Vikas Kumar wrote:
please explain me the instructions of importing it to android studio
On Sun, Jun 19, 2016 at 10:37 PM, Vikas Kumar vikas...@gmail.com wrote:
but sir you have mentioned in your stackoverflow question that you have
not read the instructions and done reading instructions then you were
successful after that can you tell me what else I have to do besides doing
these all things
1).create the ODK folder and then make repo of google play services and
then make repo of gradle config and then at last repo of collect and after
that importing collect/gradle to android studio what else I should do
On Sun, Jun 19, 2016 at 8:45 PM, Gede Ananda Nartapradnyana < 13....@stis.ac.id> wrote:
Dear Vikas,
I'm sorry that's all i know, lastly try update your sdk and set up your
git in android studio. Last time i didn't set up my git in my android
studio and i didn't download the google api's from each sdk.
Gede
On Fri, Jun 17, 2016 at 2:51 AM, Vikas Kumar vikas...@gmail.com wrote:
Sir I have imported the build.gradle file but now I am getting another
error and this is the error
https://groups.google.com/d/topic/opendatakit-developers/6FOlOztEME4/unsubscribe
opendatakit-developers+unsubscribe@googlegroups.com.
Hi Vikas,
I understand that you are having problems installing the source, but there
are a lot of people on this list and minute-by-minute updates are not
helpful.
When someone has a suggestion on how to fix your problem, I'm sure
they will respond.
··· -- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.
On Mon, Jun 13, 2016 at 5:56 PM, Vikas Kumar vikaskum660@gmail.com wrote:
from morning I am trying to build gradle but it is only downloading
On Mon, Jun 13, 2016 at 8:25 PM, Vikas Kumar vikaskum660@gmail.com wrote:
It is building gradle but taking a lot of time
On Mon, Jun 13, 2016 at 8:24 PM, Vikas Kumar vikaskum660@gmail.com wrote:
can you tell me how much time it takes to build the gradle
On Mon, Jun 13, 2016 at 9:28 AM, Gede Ananda Nartapradnyana 13.7635@stis.ac.id wrote:
Please tell us if the solution worked :smiley:
On Mon, Jun 13, 2016 at 10:39 AM, Gede Ananda Nartapradnyana 13.7635@stis.ac.id wrote:
I'm sorry i've never got that error, but i've tried to find someone
with the same problem as you, maybe this will help you
http://stackoverflow.com/questions/19678137/create-new-project-on-android-error-studio-unknown-host-services-gradle-org
On Mon, Jun 13, 2016 at 2:09 AM, Vikas Kumar vikaskum660@gmail.com wrote:
please help me I am in a big trouble if you can not help me than also
reply so that I do not depend upon you
https://groups.google.com/d/topic/opendatakit-developers/6FOlOztEME4/unsubscribe.
gradle building usually takes 5-10 minutes depends on your proc and
complexity of programs.
Have you pull the repository from the git, correctly ?
··· On Mon, Jun 13, 2016 at 10:02 PM, Yaw Anokwa wrote:
Hi Vikas,
helpful.
they will respond.
also
the
Hi Vikas,
Gede
On Mon, Jun 13, 2016 at 9:28 AM, Gede Ananda Nartapradnyana < 13.7635@stis.ac.id> wrote:
On Mon, Jun 13, 2016 at 10:39 AM, Gede Ananda Nartapradnyana < 13.7635@stis.ac.id> wrote:
the Google Groups "ODK Developers" group.
Hi Vikas,
I've tried to reproduce this issue and not able to do so. Are you
still having this problem? What have you tried so far?
On Wed, Jun 29, 2016 at 8:45 AM, Vikas Kumar vikaskum660@gmail.com wrote:
No I am not able to resolve it I am asking the question from last two weeks
and I am also trying to find but unable to get any solution if you get any
Thank you
these all things
On Sun, Jun 19, 2016 at 8:45 PM, Gede Ananda Nartapradnyana 13....@stis.ac.id wrote:
Dear Vikas,
git in android studio. Last time i didn't set up my git in my android studio
Gede
yes I have put my gradle repository properly according to the instructions
given in the read me file
according to thst I have created an ODK folder and then made repo of google
play services and gradle config and collect app and then I have imported
the collect/build.gradle file to the android studio
··· On Thu, Jun 16, 2016 at 6:50 AM, Gede Ananda Nartapradnyana < 13.7635@stis.ac.id> wrote:
Hi Vikas,
Gede
also reply so that I do not depend upon you
I am sending you the full report please have a look at it. It will tell you
what all steps I have followed
ODK_REPORT.docx (734 KB)
··· On Thu, Jul 21, 2016 at 5:10 AM, Yaw Anokwa wrote:
Hi Vikas,
weeks
any
Thank you
have
doing
these all things
and
after
Dear Vikas,
your
android studio
Gede
another
the
the
I think gradle file has been imported but now I am getting this error help
me fast else I will loose my internship.
google play services and gradle config and collect app and then I have
imported the collect/build.gradle file to the android studio
Hi Vikas,
Gede
(1) Use Java 8, not java 7. The most recent Android Studio only works with
8.
(2) Since you git cloned all of the projects, you should not Android
Studio / File / New / Project From Version Control
Instead, Android Studio / File / Import Project...
and select the build.gradle in the collect directory that you have already
pulled.
The New / Project From Version Control clones the project in a crazy place
and not in the needed directory in relation to gradle-config.
you what all steps I have followed
On Thu, Jul 21, 2016 at 5:10 AM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi Vikas,
weeks
any
Thank you
have
doing
these all things
and
after
Dear Vikas,
your
android studio
Gede
another
the
the
Groups
an
Sorry, Instead, Android Studio / File / New / Import Project...
8.
already pulled.
Hi Vikas,
weeks
any
On Wed, Jun 29, 2016 at 7:54 PM, Achyut Bhandiwad <achyut.b6@gmail.com wrote:
Thank you
have
were
besides doing
these all things
and
and after
do
Dear Vikas,
your
android studio
Gede
another
in the
to
the
Groups
an
sorry for the late reply but
still i am getting that error
with 8.
already pulled.
place and not in the needed directory in relation to gradle-config.
Hi Vikas,
two weeks
get any
On Wed, Jun 29, 2016 at 7:54 PM, Achyut Bhandiwad < achyut.b6@gmail.com> wrote:
Thank you
have
were
besides doing
these all things
services and
and after
do
Dear Vikas,
up your
android studio
Gede
another
in the
to
in the
to
the
Groups
send an
an email to opendatakit-developers+unsubscribe@googlegroups.com.
I have search this error on stackoverflow and I have found that you also
also asked the same question 5 months ago
instructions given in the read me file
Hi Vikas,
Gede
We recently had somebody running into this same error. I don't use Android
Studio and English is his second language, so I can't explain anything
beyond what he said about the solution:
"If you're interested, there the line "commandLine 'git', 'rev-parse',
'--short', 'HEAD'" in runnables.gradle file of the gradle-config repo. It
uses the git to get the SHA1 hash of the head branch for some reason. But
as the repos was just pulled there were no branches and it fired the error.
So I initialized the git and made initial commits for every repos and it
worked."
Hope that helps.
Chris
with 8.
already pulled.
Hi Vikas,
two weeks
get any
Thank you
studio
you have
were
besides doing
these all things
services and
and after
should do
Dear Vikas,
up your
android studio
Gede
another
in the
email to
in the
to
the
Groups
send an
now I am getting this error on line 45 in build.gradle file
Error:(45, 0) Could not find property 'shouldSign' on
SigningConfig_Decorated{name=release, storeFile=null, storePassword=null,
keyAlias=null, keyPassword=null, storeType=null}.
Open
File
worked."
Hope that helps.
Chris
with 8.
already pulled.
tell you what all steps I have followed
Hi Vikas,
two weeks
get any
Thank you
studio
you have
were
besides doing
these all things
services and
and after
should do
Dear Vikas,
up your
android studio
Gede
another
topic in the
email to
in the
email to
the
Groups
send an
To unsubscribe from this topic, visit https://groups.google.com/d/
What changes he has done can you please tell me
Open
File
On Thu, Aug 4, 2016 at 3:18 AM, Christopher Robert crobert@surveycto.com wrote:
Android Studio and English is his second language, so I can't explain
anything beyond what he said about the solution:
worked."
Hope that helps.
Chris
with 8.
Android Studio / File / New / Project From Version Control
already pulled.
Hi Vikas,
two weeks
get any
Thank you
studio
you have
you were
besides doing
these all things
services and
collect and after
should do
Dear Vikas,
set up your
android studio
Gede
getting another
topic in the
email to
topic in the
email to
in the
to
Groups
send an
To unsubscribe from this topic, visit https://groups.google.com/d/to
send an email to opendatakit-developers+unsubscribe@googlegroups.com.
The steps I do on Windows to set up my development environment are:
(1) Create an empty directory.
(2) use command-line git:
git clone https://github.com/opendatakit/google-play-services.git
git clone https://github.com/opendatakit/collect.git
git clone https://github.com/opendatakit/gradle-config.git
(3) These will automatically set these projects to the tip of master.
Now change gradle-config to be at the version required by collect/settings.gradle (e.g., 40)
cd gradle-config
git checkout 40
(4) Open Android Studio v2.1.2 (June 2016)
New /Import Project... collect/build.gradle
.... and it builds without error.
When building a signed APK, you need to set some environment variables to specify how to access the keystore:
ext.signStoreFilePath = System.getenv("KEYSTORE")
ext.signStorePass = System.getenv("KEYSTORE_PASSWORD")
ext.signKeyAlias = System.getenv("KEY_ALIAS")
ext.signKeyPass = System.getenv("KEY_PASSWORD")
ext.shouldSign = System.getenv("KEYSTORE") != null
By default these would not be set.
Error:(45, 0) Could not find property 'shouldSign' on SigningConfig_Decorated{name=release, storeFile=null, storePassword=null, keyAlias=null, keyPassword=null, storeType=null}.
Open File
We recently had somebody running into this same error. I don't use Android Studio and English is his second language, so I can't explain anything beyond what he said about the solution:
"If you're interested, there the line "commandLine 'git', 'rev-parse', '--short', 'HEAD'" in runnables.gradle file of the gradle-config repo. It uses the git to get the SHA1 hash of the head branch for some reason. But as the repos was just pulled there were no branches and it fired the error. So I initialized the git and made initial commits for every repos and it worked."
Hope that helps.
Chris
(1) Use Java 8, not java 7. The most recent Android Studio only works with 8.
(2) Since you git cloned all of the projects, you should not Android Studio / File / New / Project From Version Control
and select the build.gradle in the collect directory that you have already pulled.
The New / Project From Version Control clones the project in a crazy place and not in the needed directory in relation to gradle-config.
I am sending you the full report please have a look at it. It will tell you what all steps I have followed
Hi Vikas,
Thank you
these all things
Dear Vikas,
Gede
You received this message because you are subscribed to a topic in the Google Groups "ODK Developers" group.
To unsubscribe from this topic, visit https://groups.google.com/d/topic/opendatakit-developers/6FOlOztEME4/unsubscribe.
To unsubscribe from this group and all its topics, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
You received this message because you are subscribed to the Google Groups "ODK Developers" group.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
