We have a form which when pulled from aggregate, works very fine for the
first iteration on the app via FILL BLANK FORM till the end. However, it
starts giving error when we try to do the 2nd iteration via FILL THE BLANK
FORM. This is pretty weird, since if there is some code issue in the form,
it should be evident in the first cycle of filling the form too. But it
only comes in 2nd iteration onwards.
My question: Is it possible for the stored-not-yet-sent data to cause issue
on the running form being filled?
I have the XML code file if someone wants to run a test and figure out a
solution.
It may be a "stack overflow" due to a very long expression in your
relevance, constraint, or calculation columns. See, Collect loads forms
from the original XML (slowly) the first time, then loads from a serialized
representation (more quickly) all subsequent times. When loading from the
serialized representation, it is susceptible to stack-overflow errors when
expressions are lengthy. To verify, you can remove any ultra-long
expressions and retry.
If you're using ODK Collect, you likely need to shorten your expressions
(e.g., by splitting them up into multiple calculation fields). If you're
using SurveyCTO Collect, you can request an upgrade since our latest
version will fall back automatically to the slower loading when required by
the form (but, if you want a quick form load, you should still shorten your
expressions).
Chris
On Mon, Sep 8, 2014 at 4:49 AM, Saad wrote:
I am facing a strange issue.
issue on the running form being filled?
solution.
Which version of android are you running? Stock or custom Rom?
Thanks and Regards
Ronald Munjoma
solution.
relevance, constraint, or calculation columns. See, Collect loads forms from
using SurveyCTO Collect, you can request an upgrade since our latest version
will fall back automatically to the slower loading when required by the form
expressions).
it should be evident in the first cycle of filling the form too. But it only
solution.
Yep, nothing more clever than that! It looked difficult to fix the root
cause and our poor users had seen one too many of these errors. It also
pops up a screen while loading to explain that they can speed it up by
shortening expressions.
Chris
On Sep 8, 2014 8:36 AM, "Yaw Anokwa" wrote:
Chris,
I'm curious how do you do the fallback? Do you catch the exception and
retry with the XML or do you have something more clever?
from
when
version
form
expressions).
BLANK
form,
only
solution.
