StreamNewSubmissionDataONLY not working
Hi, dear all.
I'm using aggregate v1.4.12
The option " Stream New Data ONLY" is not working, when publishing data to
Google Spreadsheet;
because of this, I often use " Stream Both Existing and New Data".
In advance, thanks for your help.
Regards,
Hi Amal,
Is it possible you can setup a test Aggregate 1.4.13 server and see if
you can replicate the issue there? I ask because 1.4.13 rewrote the
Sheets publisher to use a newer API and so that might have a fix.
ยทยทยท On Mon, May 8, 2017 at 12:10 PM, Amal wrote: > Hi, dear all. > I'm using aggregate v1.4.12 > The option " Stream New Data ONLY" is not working, when publishing data to > Google Spreadsheet; > because of this, I often use " Stream Both Existing and New Data". > In advance, thanks for your help. > Regards, > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups > "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
