Sub Location - Based on Location
I have a requirement to show list of subloation based on Location
Example:
Sub Location:
Newyork
Washington
Chicago
Sub Location
London
Oxford
Ireland
Please suggest how to control list options on the basis of response in one
list.
Regards
techbyte101
Use cascading selects.
http://opendatakit.org/help/form-design/cascading-selects. If you are
using XLS Form, see the Cascading Selects section at
http://opendatakit.org/help/form-design/xlsform/.
··· -- Need ODK help? Go to http://nafundi.com for custom development, form design, implementation support, and user training for ODK.
Example:
Sub Location:
Newyork
Washington
Chicago
Sub Location
London
Oxford
Ireland
list.
Regards
techbyte101
"ODK Developers" group.
Thanks.
I looked at the reference and try to use in my form. I need only 2 levels
state and county, somehow it showing empty drop down without label.
Please see attached file if you can help.
Regards
techbyte101
Fabric Care_v9.xml (93 KB)
··· On Saturday, February 23, 2013 11:43:56 AM UTC+5:30, Yaw Anokwa wrote: > > Use cascading selects. > http://opendatakit.org/help/form-design/cascading-selects. If you are > using XLS Form, see the Cascading Selects section at > http://opendatakit.org/help/form-design/xlsform/. > > Yaw > -- > Need ODK help? Go to http://nafundi.com for custom development, form > design, implementation support, and user training for ODK. > > On Fri, Feb 22, 2013 at 10:11 PM, techbyte <techb...@gmail.com> wrote: > > I have a requirement to show list of subloation based on Location > > > > Example: > > Location: US > > Sub Location: > > Newyork > > Washington > > Chicago > > > > Location: UK > > Sub Location > > London > > Oxford > > Ireland > > > > Please suggest how to control list options on the basis of response in > one > > list. > > > > Regards > > techbyte101 > > > > -- > > You received this message because you are subscribed to the Google > Groups > > "ODK Developers" group. > > To unsubscribe from this group and stop receiving emails from it, send > an > > email to opendatakit-developers+unsubscribe@googlegroups.com. > > > For more options, visit https://groups.google.com/groups/opt_out. > > > > >
Able to show labels, but still values are not coming in drop down.
Fabric Care_v9.xml (93.8 KB)
··· On Sunday, February 24, 2013 10:04:21 PM UTC+5:30, techbyte wrote: > > Thanks. > > I looked at the reference and try to use in my form. I need only 2 levels > state and county, somehow it showing empty drop down without label. > > Please see attached file if you can help. > > Regards > techbyte101 > > > On Saturday, February 23, 2013 11:43:56 AM UTC+5:30, Yaw Anokwa wrote: >> >> Use cascading selects. >> http://opendatakit.org/help/form-design/cascading-selects. If you are >> using XLS Form, see the Cascading Selects section at >> http://opendatakit.org/help/form-design/xlsform/. >> >> Yaw >> -- >> Need ODK help? Go to http://nafundi.com for custom development, form >> design, implementation support, and user training for ODK. >> >> On Fri, Feb 22, 2013 at 10:11 PM, techbyte wrote: >> > I have a requirement to show list of subloation based on Location >> > >> > Example: >> > Location: US >> > Sub Location: >> > Newyork >> > Washington >> > Chicago >> > >> > Location: UK >> > Sub Location >> > London >> > Oxford >> > Ireland >> > >> > Please suggest how to control list options on the basis of response in >> one >> > list. >> > >> > Regards >> > techbyte101 >> > >> > -- >> > You received this message because you are subscribed to the Google >> Groups >> > "ODK Developers" group. >> > To unsubscribe from this group and stop receiving emails from it, send >> an >> > email to opendatakit-developers+unsubscribe@googlegroups.com. >> > For more options, visit https://groups.google.com/groups/opt_out. >> > >> > >> >
I am trying to use cascading select in my form (state and county). Getting
below error on validation
Selection choice label text and image uri are both missing for:
/data/QuestProfile/state choice: 1.
/data/QuestProfile/state choice: 2.
Dynamic select question has no choices!
[instance(choices)/states/state/counties/county]. If this occurs while
filling out a form (and not while saving an incomplete form), the filter
condition may have eliminated all the choices. Is that what you intended?
Fabric Care_v9.xml (94.1 KB)
Thanks.
Regards
techbyte101
Example:
Sub Location:
Newyork
Washington
Chicago
Sub Location
London
Oxford
Ireland
one
list.
Regards
techbyte101
Groups
an
The first two errors are of concern. The last (dynamic select question has
no choices) is not.
The first two errors say that for choice '1' and '2', you specified an item
value, but there is no item label or no image icon for the item. You must
have at least one of those in order to render that choice selection to the
user.
The last error just communicates that you're using a cascading select where
the available choices are dependent upon values specified earlier in the
form. Since those values are all blank (because we haven't filled in the
form), the validation logic sees the list of choices as being blank too
(since the values in the filtering conditions are all blank, those
filtering conditions fail, and you end up with no choices).
Thanks.
levels state and county, somehow it showing empty drop down without label.
Regards
techbyte101
http://opendatakit.org/help/**form-design/cascading-selectshttp://opendatakit.org/help/form-design/cascading-selects.
If you are
http://opendatakit.org/help/**form-design/xlsform/http://opendatakit.org/help/form-design/xlsform/.
Example:
Sub Location:
Newyork
Washington
Chicago
Sub Location
London
Oxford
Ireland
in one
list.
Regards
techbyte101
Groups
send an
email to opendatakit-developers+**unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out.
Able to remove errors and to show data in first DropDown
But second drop down still not getting populated on the basis of first.
Please see attached form and help
Fabric Care_v9.xml (94.6 KB)
··· On Wednesday, February 27, 2013 12:15:12 AM UTC+5:30, Mitch wrote: > > The first two errors are of concern. The last (dynamic select question has > no choices) is not. > > The first two errors say that for choice '1' and '2', you specified an > item value, but there is no item label or no image icon for the item. You > must have at least one of those in order to render that choice selection to > the user. > > The last error just communicates that you're using a cascading select > where the available choices are dependent upon values specified earlier in > the form. Since those values are all blank (because we haven't filled in > the form), the validation logic sees the list of choices as being blank too > (since the values in the filtering conditions are all blank, those > filtering conditions fail, and you end up with no choices). > > Mitch > > On Tue, Feb 26, 2013 at 6:11 AM, techbyte <techb...@gmail.com wrote: > >> I am trying to use cascading select in my form (state and county). >> Getting below error on validation >> >> Selection choice label text and image uri are both missing for: >> /data/QuestProfile/state choice: 1. >> >> Selection choice label text and image uri are both missing for: >> /data/QuestProfile/state choice: 2. >> >> Dynamic select question has no choices! >> [instance(choices)/states/state/counties/county]. If this occurs while >> filling out a form (and not while saving an incomplete form), the filter >> condition may have eliminated all the choices. Is that what you intended? >> >> >> ----------------------------------- >> >> >> >> On Sunday, February 24, 2013 10:26:45 PM UTC+5:30, techbyte wrote: >>> >>> Able to show labels, but still values are not coming in drop down. >>> >>> >>> On Sunday, February 24, 2013 10:04:21 PM UTC+5:30, techbyte wrote: >>>> >>>> Thanks. >>>> >>>> I looked at the reference and try to use in my form. I need only 2 >>>> levels state and county, somehow it showing empty drop down without label. >>>> >>>> Please see attached file if you can help. >>>> >>>> Regards >>>> techbyte101 >>>> >>>> >>>> On Saturday, February 23, 2013 11:43:56 AM UTC+5:30, Yaw Anokwa wrote: >>>>> >>>>> Use cascading selects. >>>>> http://opendatakit.org/help/**form-design/cascading-selects. >>>>> If you are >>>>> using XLS Form, see the Cascading Selects section at >>>>> http://opendatakit.org/help/**form-design/xlsform/. >>>>> >>>>> >>>>> Yaw >>>>> -- >>>>> Need ODK help? Go to http://nafundi.com for custom development, form >>>>> design, implementation support, and user training for ODK. >>>>> >>>>> On Fri, Feb 22, 2013 at 10:11 PM, techbyte wrote: >>>>> > I have a requirement to show list of subloation based on Location >>>>> > >>>>> > Example: >>>>> > Location: US >>>>> > Sub Location: >>>>> > Newyork >>>>> > Washington >>>>> > Chicago >>>>> > >>>>> > Location: UK >>>>> > Sub Location >>>>> > London >>>>> > Oxford >>>>> > Ireland >>>>> > >>>>> > Please suggest how to control list options on the basis of response >>>>> in one >>>>> > list. >>>>> > >>>>> > Regards >>>>> > techbyte101 >>>>> > >>>>> > -- >>>>> > You received this message because you are subscribed to the Google >>>>> Groups >>>>> > "ODK Developers" group. >>>>> > To unsubscribe from this group and stop receiving emails from it, >>>>> send an >>>>> > email to opendatakit-developers+**unsubscribe@googlegroups.com. >>>>> > For more options, visit https://groups.google.com/**groups/opt_out. >>>>> >>>>> > >>>>> > >>>>> >>>> -- >> You received this message because you are subscribed to the Google Groups >> "ODK Developers" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit-developers+unsubscribe@googlegroups.com >> . >> For more options, visit https://groups.google.com/groups/opt_out. >> >> >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com
ODK Collect does not support having one question on a screen with value
dependencies on another.
In this case, you have both the State and County drop-downs shown on the
same screen (field-list group).
Since County values are dependent upon State values, this causes a
problem.
The solution is to as for the State on one screen, then on a subsequent
screen, ask for the County.
Otherwise, your form works -- if you select a State then swipe forward and
backward, the County drop-down now has the correct list of counties for the
chosen State.
has no choices) is not.
the user.
Dynamic select question has no choices! [instance(choices)/states/**state/counties/county].
If this occurs while filling out a form (and not while saving an incomplete
form), the filter condition may have eliminated all the choices. Is that
what you intended?
Thanks.
Regards
techbyte101
http://opendatakit.org/help/**fo**rm-design/cascading-selectshttp://opendatakit.org/help/form-design/cascading-selects.
If you are
http://opendatakit.org/help/**fo**rm-design/xlsform/http://opendatakit.org/help/form-design/xlsform/.
Example:
Sub Location:
Newyork
Washington
Chicago
Sub Location
London
Oxford
Ireland
in one
list.
Regards
techbyte101
Groups
send an
For more options, visit https://groups.google.com/**grou**
ps/opt_out https://groups.google.com/groups/opt_out.
an email to opendatakit-developers+**unsubscribe@googlegroups.com.
mitche...@gmail.com
