I tried to search and nothing came up. Just to confirm, is there a
sub-string function available in ODK?
/r
Nik
/r
Nik
On the opendatakit.org help pages
http://opendatakit.org/help/form-design/binding/ , there is a link to the
source code for the functions available in ODK (Javarosa)
https://bitbucket.org/javarosa/javarosa/src/tip/core/src/org/javarosa/xpath/expr/XPathFuncExpr.java#cl-128
That source code shows that there are "substr(str,startindex)" and
"substr(str,startindex,endindex)" functions defined.
These functions index into the string at position 0, so substr(str, 0) is
equal to str.
Negative indicies can be used for startindex and endindex, in which case
they are interpreted as starting from the end of the string.
"string-length(str)" may be a useful function to obtain the length of a
string.
"concat(str1, str2, ...)" will concatenate two or more strings together.
sub-string function available in ODK?/r
Nik--
Thank you Mitch for the info and the link.
/r
Nik
https://bitbucket.org/javarosa/javarosa/src/tip/core/src/org/javarosa/xpath/expr/XPathFuncExpr.java#cl-128That source code shows that there are "substr(str,startindex)" and
"substr(str,startindex,endindex)" functions defined.These functions index into the string at position 0, so substr(str, 0) is
equal to str.
they are interpreted as starting from the end of the string."string-length(str)" may be a useful function to obtain the length of a
string."concat(str1, str2, ...)" will concatenate two or more strings together.
On Sun, Jul 8, 2012 at 3:55 AM, ゴー・ニコライ <nikolai.go@gmail.com<javascript:_e({}, 'cvml', 'nikolai.go@gmail.com');> wrote:
Nik--
Post: opendatakit@googlegroups.com <javascript:_e({}, 'cvml',
'opendatakit@googlegroups.com');>
Unsubscribe: opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>
mitchellsundt@gmail.com <javascript:_e({}, 'cvml',
'mitchellsundt@gmail.com');>--
