Ha,
When I have downloaden the survey I can't fill in the survey at all. Can't
change the date and time, and can't type anything. Can anyone help me with
this problem.
Kind regards
Ha,
this problem.
Kind regards
Hereby the XML file, it was working last week since I have uploaded a new
XML file it isn't working anymore.
Kind regards
Boom observatie JSOOC.xml (5.9 KB)
If made it in Build ODK and then exported to an xml file. Maybe I can try
to make a new survey?
Could you please specify your problem a little more? Perhaps attach a copy
of your xlsx or xlm form.
Kind regards,
Stephan
Ha,
this problem.Kind regards
Stephan Playfair
Officer Research and Development
Foundation for Forest Management and Production Control
Paramaribo, Suriname
I went through your xml file and it seems as if you do not have any text
input specified. Please check whether you have any "text" input in your
excel file (if you used xls format). Or if you wish, please upload your
excel file so we make look at it.
XML file it isn't working anymore.Kind regards
On Tuesday, January 17, 2017 at 2:31:16 PM UTC-3, janstarkeople...@gmail.com wrote:
Ha,
Can't change the date and time, and can't type anything. Can anyone help me
with this problem.Kind regards
Stephan Playfair
Try to do so. But perhaps try to use excel as a way of building your forms.
This gives you somewhat more freedom.
If you require any help, call +597-483131 and ask for the department of
research and development of the foundation for forest management and
production control (SBB).
We will be more than happy to assist.
Kind regards,
Stephan
Thank u so much for ur help at this point. Today I am going to try to make
a form using excel. Then try again using ODK collect. If it still don't
work, I will contact you. Is that allright for you?
Thank u so much for ur time.
The only question that I have left is, how I get my XLSform into aggregate
without using the SD of my phone. Is that possible?
Got it!!!
Thanks u so much for al your help!
