I am developing a survey for forest enumeration as part of a REDD project.
One of the key biomass parameters are shrubs. Our current methodology
simply records the shrub and places it into a size class based on the
height of the shrub (small: Below knee height, medium: knee to shoulder,
large: above shoulder). In practice a field plot technician walks around
the plot and calls out the sizes as he encounters the shrubs, another field
technician then records the number of shrubs per size group. Currently, I
have a "begin repeat" with a select_one inside giving the technician the
option to select either small medium or large. This should work but
presents a couple of issues.
The begin repeat will create a separate table on aggregate which is
problematic for automating data processing later on. I am sure this can be
overcome with some javascripting online but would prefer the number of each
shrub be recorded in the main table.
Secondly, the "would you like to add another" option can be problematic
in the field.
My question is thus, is there an option where I split the input screen into
three sections one for each size class. The technician will then have the
option of tapping a size class to record an occurrence. The table would
then contain three name variables (three size groups) with the number of
shrubs recorded in each.
Many thanks and looking forward to your responses,
Regards
Wes
With this approach, you could write your own 'tap' app that had 3 buttons,
and returned 3 data values into the form.
Perhaps the teams that need this could pool their resources and submit a
patch?
On Wed, Sep 19, 2012 at 2:54 AM, Wes Roberts wrote:
Dear ODK community,
in the field.
into three sections one for each size class. The technician will then have
the option of tapping a size class to record an occurrence. The table would
Regards
Wes
I should also add that currently you can launch an external android app
from collect but right now it can only accept one value back. The launch of
the external android app is mapped to a single question which in xforms
maps to a single value. Here are some links to previous threads on it.
As a quick hack you could have the 3 values returned as a string (need to
use string type) do some parsing on that string after the submission. For
example you could encode the string with a key value pairs. An example
could be 'small=12;medium=34;large=2'. You would then need to parse this
information once exported.
This is being fixed in the ODK 2.0 toolset where you can map a widget to
any number of values/questions in the form. However, with xforms and
javarosa they like one value per question and we have not figured out how
we would want to work around that. Examples like GPS and Multi-select still
have one answer value that requires special parsing similar to what is
suggested above.
Hope this was helpful explaining the constraints.
Waylon
project. One of the key biomass parameters are shrubs. Our current
methodology simply records the shrub and places it into a size class based
on the height of the shrub (small: Below knee height, medium: knee to
shoulder, large: above shoulder). In practice a field plot technician walks
around the plot and calls out the sizes as he encounters the shrubs,
another field technician then records the number of shrubs per size group.
Currently, I have a "begin repeat" with a select_one inside giving the
technician the option to select either small medium or large. This should
work but presents a couple of issues.
problematic in the field.
Regards
Wes
I agree, perhaps we can pool our abilities and add the functionality to
ODK, Would be great to learn more about the development side of things. The
groups mentioned have been copied to email.
I still need to get my head around the launching of an external app but I
see this as being beneficial especially for measuring the height of trees.
I like the idea of using a string of numbers and simply counting the
occurence post form upload. Lets say for example small is 1, medium is 2,
large is 3 - an input could look something like this shrubs:
11111222221111131111333222. Also inputs could be constrained to .<4 or
something like that. For this to work the input screen would need to be
numbers only, will need to see if this is possible and what the maximum
length of string / integer is.
Thanks for the ideas, our form is still a long way off being operational so
we have time to test and develop.
Regards and thanks for the wonderful application, this is really going to
speed up data collection and processing.
Regards,
Wesley
> http://groups.google.com/group/opendatakit/browse_thread/thread/88fc497a01c99e78/cb15c9de739a554a?lnk=gst&q=launch+external+app#cb15c9de739a554a
> http://groups.google.com/group/opendatakit/browse_thread/thread/1e4555d0e969e3cd/37d319b148a0f381?lnk=gst&q=launching+external+app#37d319b148a0f381
> suggested above.
> Waylon
>> Several groups (corey@servalproject.org , prabhas.pokharel@gmail.com )have asked for 'group-of-data-values' submissions using custom external
>> apps to gather the data.
>> I don't have time to implement this, but I've referred everyone to this
>> plan:
>> http://code.google.com/p/opendatakit/wiki/XFormControlExtensionProposal
>> buttons, and returned 3 data values into the form.
>> patch?
>> Mitch
>>> Dear ODK community,
>>> 1. The begin repeat will create a separate table on aggregate which is
>>> 2. Secondly, the "would you like to add another" option can be
>>> Regards
>>> Wes
>>> Post: opendatakit@googlegroups.com
>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com
>>> Options: http://groups.google.com/group/opendatakit?hl=en
>> Mitch Sundt
>> Software Engineer
>> University of Washington
>> mitchellsundt@gmail.com
If you're storing a long list of digits in a string, keep in mind that ODK
Aggregate has storage limitations -- it will truncate any string to 256
characters unless you specify an explicit maximum string length -- see http://opendatakit.org/help/form-design/guidelines/ at the bottom of the
page ( Datastore String Length ). This is a limit in ODK Aggregate. I do
not believe ODK Collect imposes any meaningful limit on the length of
strings it can record.
On Wed, Sep 19, 2012 at 11:37 PM, Wes Roberts wrote:
Dear Mitch and Waylon,
Many thanks for your inputs and info.
so we have time to test and develop.
Regards,
Wesley
suggested above.
Regards
Wes
We have some hardcopy data sheets from previous sampling campaigns which I
will use to determine the string length required. I doubt we will encounter
a plot with more than 256 shrubs.
Regards,
Wesley
Regards,
Wesley
to use string type) do some parsing on that string after the submission.
For example you could encode the string with a key value pairs. An example
suggested above.
Regards
Wes
