LINKS (http://linkssystem.org) is an ODK-based data collection,
reporting, and management system created by the The Task Force for
Global Health. As part of their work, the LINKS team provides their
users with a finalized dataset and a codebook that explains that
dataset. Generating a codebook can be tedious work, so the LINKS team
hired the consultants at Nafundi (http://nafundi.com) to automate the
process.
Nafundi has created LINKS Codebook, a desktop application which takes
an ODK compliant XForm and generates a codebook in PDF (with multiple
languages). Codebook is perfect for users who download ODK datasets
and need to understand what variables correspond with what prompts.
It's free, easy to use, and as you can see at http://opendatakit.org/2013/06/task-force-and-nafundi-release-codebook-generator-for-odk,
produces beautiful codebooks.
This looks like a great addition. I just tried running the programme on a
few test forms, but each time I got an error message e.g.
Error: Failed to make codebook because null.
/usr/share/fonts/truetype/ARIALUNI.TTF not found as file or resource..
Am running this on PCLinuxOS and am guessing that my fonts are in a
different directory to the path listed in the second error - any way to
point them to the correct place / substitute the fonts as can't seem to
find ARIALUNI.TTF?
Great tool there. I have used it for a while and it worked perfectly. But
since yesterday, ive tried using the codebook and i get the error 'Failed
to make codebook because null. Processing default language'. Please what
could be the problem I have read through below but did not find any
solution.
> process.
> Download and try LINKS Codebook v1.1 at
> http://linkssystem.org/support/Task-Force-LINKS-Codebook-v1.1.zip
Do you happen to know where your fonts directory is? Maybe
/usr/share/fonts? And is there a font there that looks like Arial
Unicode MS or something similar?
On Thu, Jun 13, 2013 at 3:26 AM, dj_bridges wrote:
> CONGRATULATIONS Yaw and the rest of the team.
> point them to the correct place / substitute the fonts as can't seem to find
> ARIALUNI.TTF?
> "ODK Community" group.
> For more options, visit https://groups.google.com/groups/opt_out.
I tried it as soon as I saw your post. But like Dan, I too got some errors:
Error: Failed to make codebook because 1.
find ARIALUNI.TTF?
The error I had was fixed when i removed the choice filter option from the
xls form.
> solution.
>> process.
On Tue, Mar 7, 2017 at 1:59 AM, Ayub wrote:
> Dear Yaw,
> Firstly, thanks for this much needed feature.
> However, It gives following message to me:
> Error: Failed to make codebook because XPath evaluation: cannot handle
> function 'pulldata'.
> I suppose if it ignores this, even then PDF would just be fine.
> Best,
> Ayub
On Thu, Jun 13, 2013 at 3:33 AM, Vinia Marciano wrote:
> Congratulations, Yaw! :)
>> ARIALUNI.TTF?
Have done a bit more experimenting and found out the following:
My fonts are contained with the same tree as that coded into the
program (all of them are under various folders in /usr/share/fonts e.g.
Arial is in /usr/share/fonts/webcore). Perhaps Codebook can search within
the parent /usr/share/fonts?
Copying and renaming an Arial Unicode MS font into a new path ie
/usr/share/fonts/truetype/ARIALUNI.TTF was valid, and reloading the
codebook enabled me to build the codebook from simple forms without any
errors.
With more complex forms the system still often gives this: Error:
I really like the output of this software. Is there any chance the output
could also be as a spreadsheet to allow some editing where complex logic is
present that the application can't quite follow? Users could then output it
as a .pdf as required....
Cheers
Dan
On Thursday, 13 June 2013 16:18:58 UTC+2, Yaw Anokwa wrote:
> Daniel,
> Yaw
> a
> find
> > ARIALUNI.TTF?
> Groups
> an
a
find
Thanks, Nathaniel! Deleting the 'choice filter' column resolved the error for me as well.
On Wednesday, May 11, 2016 at 6:30:52 PM UTC+3, Nathaniel Amoh Boateng wrote:
> The error I had was fixed when i removed the choice filter option from the xls form.
> Great tool there. I have used it for a while and it worked perfectly. But since yesterday, ive tried using the codebook and i get the error 'Failed to make codebook because null. Processing default language'. Please what could be the problem I have read through below but did not find any solution.
> On Wednesday, 12 June 2013 14:39:07 UTC, Yaw Anokwa wrote:LINKS (http://linkssystem.org) is an ODK-based data collection,
> process.
a
find
ARIALUNI.TTF?
I've filed your issues in our issue tracker, and we'll try to get it
in the next update that Task Force asks for. It's unlikely we'll ever
support spreadsheets, but we could create HTML versions of the
codebook as part of the output.
Please send me the forms you are having problems with.
My fonts are contained with the same tree as that coded into the program
(all of them are under various folders in /usr/share/fonts e.g. Arial is in
/usr/share/fonts/webcore). Perhaps Codebook can search within the parent
/usr/share/fonts?
/usr/share/fonts/truetype/ARIALUNI.TTF was valid, and reloading the codebook
enabled me to build the codebook from simple forms without any errors.
With more complex forms the system still often gives this: Error: Failed to
Cheers
Dan
Daniel,
a
find
ARIALUNI.TTF?
I'll reach out to Taskforce to see if there is budget to update the
app and fix some of these problems. If you use the Codebook and wish
to fund these fixes, please email me.
On Fri, Jun 14, 2013 at 1:30 PM, Yaw Anokwa wrote:
> Dan,
> Yaw
>> /usr/share/fonts?
>> Cheers
>> Dan
>>> Daniel,
>>> Yaw
>>> > a
>>> > find
>>> > ARIALUNI.TTF?
>>> > Groups
>>> > an
>>> > email to opendatakit...@googlegroups.com.
in-field training, and software development for ODK. Go to https://nafundi.com to get started.
Hey all, are there any other solutions anyone has found for these error messages? I have tried uploading a form in both .xls, .xml, and removing the choice column.
Now I am receiving the following message: Error: Failed to process form because XML Syntax Error at Line: 3, Column: 102!.
I am working on Mac OS Sierra.
Thanks for any ideas you might have! Cheers
I have tried to use the LINKS codebook v1.1 but I still get the same error :
Processing Tigrinya language...
Could it be due to the fact that I have several languages in my form (here
tigrinya) ?
Thanks for your answer
Le mercredi 3 juillet 2013 01:01:37 UTC+2, Yaw Anokwa a écrit :
> We've had a few requests from folks who want to contribute to the
> codebook. Well, now you can!
> Task Force has open sourced the code at
> https://bitbucket.org/tfgh/codebook
> On Fri, Jun 14, 2013 at 1:30 PM, Yaw Anokwa <yan...@nafundi.com > wrote:
> > Dan,
> > Yaw
> > On Thu, Jun 13, 2013 at 11:32 PM, dj_bridges <danielj...@gmail.com > wrote:
> program
> is in
> parent
> >> /usr/share/fonts?
> codebook
> Failed to
> output
> logic is
> output it
> >> Cheers
> >> Dan
> >>> Daniel,
> >>> Yaw
> on
> >>> > a
> resource..
> to
> to
> >>> > find
> >>> > ARIALUNI.TTF?
> >>> > Groups
> send
> >>> > an
> Groups
> an
>> Hi all,
>> I've filed this issue at
>> https://bitbucket.org/tfgh/codebook/issues/7/choice_filter-causes-errors.
>> Thanks,
>> Yaw
>> >> process.
>> > You received this message because you are subscribed to the Google Groups "ODK Community" group.
>> > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com.
Worked right off the bat. Nice Job Carl and Yaw.
The "note" var type in XLSForm produces static text in the xml. The
codebook lists these as "user entered text" as if it were a text variable.
Maybe have it say "Static text" or "informational text".
Curtis
2016-02-04 10:31 GMT+01:00 Bouguen Adrien :
Hi everybody,
tigrinya) ?
program
is in
parent
/usr/share/fonts?
codebook
Failed to
output
logic is
output it
Cheers
Dan
Daniel,
Groups
send
Curtis BRODERICK
Head of technical training and user support
Health Information Systems
