Hey Yaw,
Thanks so much, your support is much appreciated! Will log it on github now.
Cheers,
Hannah
On Thu, Mar 2, 2017 at 1:24 AM, Yaw Anokwa wrote:Hi there,
I've forked the Task Force Codebook and I'll see if I can fix some of
these problems and release a new version.No ETA, but you can find the repo at
https://github.com/nafundi/odk-codebook. Can you please open an issue
there and attach your form?Thanks,
On Wed, Mar 1, 2017 at 8:17 AM, ehlleach@gmail.com wrote:
On Wednesday, June 1, 2016 at 2:34:22 PM UTC+5, Yaw Anokwa wrote:
Hi all,
I've filed this issue at
https://bitbucket.org/tfgh/codebook/issues/7/choice_
filter-causes-errors.I'll reach out to Taskforce to see if there is budget to update the
app and fix some of these problems. If you use the Codebook and wish
to fund these fixes, please email me.Thanks,
https://nafundi.com to get started.On Mon, May 30, 2016 at 3:50 PM, mulhollandge@gmail.com wrote:
Thanks, Nathaniel! Deleting the 'choice filter' column resolved the
error for me as well.On Wednesday, May 11, 2016 at 6:30:52 PM UTC+3, Nathaniel Amoh Boateng wrote:
The error I had was fixed when i removed the choice filter option
from the xls form.On Wednesday, 11 May 2016 09:34:10 UTC, Nathaniel Amoh Boateng wrote:
Great tool there. I have used it for a while and it worked
perfectly. But since yesterday, ive tried using the codebook and i get the
error 'Failed to make codebook because null. Processing default language'.
Please what could be the problem I have read through below but did not
find any solution.On Wednesday, 12 June 2013 14:39:07 UTC, Yaw Anokwa wrote:LINKS (
http://linkssystem.org) is an ODK-based data collection,reporting, and management system created by the The Task Force for
Global Health. As part of their work, the LINKS team provides their
users with a finalized dataset and a codebook that explains that
dataset. Generating a codebook can be tedious work, so the LINKS team
hired the consultants at Nafundi (http://nafundi.com) to automate
theprocess.
Nafundi has created LINKS Codebook, a desktop application which takes
an ODK compliant XForm and generates a codebook in PDF (with multiple
languages). Codebook is perfect for users who download ODK datasets
and need to understand what variables correspond with what prompts.
It's free, easy to use, and as you can see at
http://opendatakit.org/2013/06/task-force-and-nafundi-
release-codebook-generator-for-odk,produces beautiful codebooks.
Download and try LINKS Codebook v1.1 at
http://linkssystem.org/support/Task-Force-LINKS-Codebook-v1.1.zip
Groups "ODK Community" group.
send an email to opendatakit+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/d/optout.Hey all, are there any other solutions anyone has found for these error
messages? I have tried uploading a form in both .xls, .xml, and removing
the choice column.Now I am receiving the following message: Error: Failed to process form
because XML Syntax Error at Line: 3, Column: 102!.I am working on Mac OS Sierra.
Thanks for any ideas you might have! Cheers
To unsubscribe from this topic, visit https://groups.google.com/d/
topic/opendatakit/S7kznJV7tIY/unsubscribe.
