I'm using XLSForm to create my xform and have a text field with the
appearance set to number (like in the Widget sample). When I enter in
a string into the field which includes dashes, periods or spaces (I
can't seem to enter in a comma) no value appears to be recorded. When
I am in the field, I see a value but if I scroll away and scroll back
the field is blank. There is also no value in that field in Aggregate.
Am I doing something wrong? I get the same behavior with the Widget
sample. I'm using ODK 1.1.7 on a Galaxy Nexus phone.
Hi Dana,
The "number" appearance type is not in the XLSForm spec, and I'm not sure
if ODK supports it either. Is there a reason you need it? XLSForm has
integer and decimal question types which might do what you want without all
the bugs. Apologies for the broken sample form. I'm assuming it was "ODK
1.1.7 Widgets" from here: http://formhub.org/formhub_u/.
Regards,
-Nathan
On Friday, March 30, 2012 7:23:47 AM UTC-7, Dana Lee wrote:
> Hi,
> Thanks,
> Dana
You can either attach your particular form or make a sample form that
shows the problem. If the form can't be made public, email it to me.
In the email or bug report, be detailed about which question has the
problem, and the input we need to give it to reproduce that behavior.
Also, include the locale of your phone (in Settings, under Language &
Input, what is the language set to?).
On Fri, Mar 30, 2012 at 21:09, Nathan wrote:
> Hi Dana,
> The "number" appearance type is not in the XLSForm spec, and I'm not sure if
> ODK supports it either. Is there a reason you need it? XLSForm has integer
> and decimal question types which might do what you want without all the
> bugs. Apologies for the broken sample form. I'm assuming it was "ODK 1.1.7
> Regards,
> -Nathan
>> Hi,
>> Thanks,
>> Dana
Hi Nathan,
You are correct, I downloaded the sample from the formhub university.
Not a big deal that it does not work. I was planning on using this
field to record a parcel land ID that is seperated by dashes, ex:
2-4-22-5. A text string question works fine, it was just nice to have
the larger number pad on the screen.
Hi Yaw,
Not a problem, I can make a sample form and will do my best to provide
the necessary information.
Thanks for the quick answers!
Dana
On Mar 31, 9:10 am, Yaw Anokwa wrote:
> Dana,
> This might be an Android 4 locale issue.
> Could you please attach the form (both the XLS and XML) that is giving
> you problems to this bug report athttp://code.google.com/p/opendatakit/issues/detail?id=550.
> Thanks,
> Yaw
> > Hi Dana,
> > Regards,
> > -Nathan
> >> Hi,
> >> Thanks,
> >> Dana
Let's say the name of the prompt for other is called ${q1_other}. You
can put whatever is in that variable in the label of question two. So
for example, "Why do you like ${q1_other}?".
On Fri, Nov 25, 2016 at 5:18 PM, wrote:
> Hi All,
> I have just started using ODK and wanted to find out whether one call pull other specify mentions into questions that after eg
> Q1 which food do you like
> cheese
> pizza
> marcoroni
> other specify(i say spaghetti)
> I would like spaghetti to appear in the next question body...why do you like spaghetti or as part of my answers in other related questions eg...top 3 foods
> cheese
> pizza
> marcoroni
> spaghetti
> no need for other specify to appear.
> looking forward to your feedback.
> thanks,
> Paul
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com.
