I have a scenario, text question and none [multiple] on the same page.
1.if i enter something in text type question than None should not be select
2.if i select none than text type question must be blank
3. response is required in text type question or mutiple select
OKD Collect, ODk Aggregate
i have tried constraint "(not(selected(., '99')) or (${Q22B} != ''))" but all in vain
Hi @noman.s2325
Not sure I understood your case.
Could you share the xls form?
Meanwhile a couple of comments.
- I think a " symbol is missing in our constraint
should be "(not(selected(., '99')) or (${Q22B} != "''))"
- if 'none' is the only option of the select_multiple, than you can consider two alternative approaches:
- first ask if there's any text or none; if none is selected you skip the text, otherwise you move to the text question
- you use a special coding for none option (e.g. "99"). In this case you want to constraint the text answer to accept strings of minimum 3 characters and the answer '99'. This way you would avoid empty answers and the user would have a clear way to indicate that the answer is "none". You might want to include a clear hint for this question.
I hope this helps!
Andrea
