I am using text field with apperance=number for some fields to make this field accepts numeric and decimal values. But Some devices are not supported decimal inputs. But in my handset its working fine with decimal values.
I am Share the screenshot which is sent to me by my client.
ODK Collect - 1.18.2
Device - Samsung Galaxy - version - not sure
Nothing Yet.
Nothing Yet
You can try switching the keyboard from the device. You can also try installing additional keyboard if the existing keyboards do not support. Generally, multiple default keyboards exist in the devices. Try with the alternatives first.
I believe this is a device specific issue that we can't do much about. @Grzesiek2010 can you confirm?
Only Samsung devices have this issue with their default keyboard app. We have already experienced that and instructed client to use Gboard instead and the issue disappeared.
apperance=number is for numbers not decimals.
For decimal values, you need to use decimal
data type not text
with number
appearance.
Could you confirm you use appropriate types, because your description doesn't indicate it?
