how can I put a constraint on a text question which does not allow spaces to be entered?
is it possible to put a constraint on an integer question type which allows you to only put in multiples of 5 for example? If so would you have the formula?
Match a single character not present in the list below [^ ]+ + Quantifier — Matches between one and unlimited times, as many times as possible, giving back as needed (greedy) " " matches the space character literally (case sensitive)
$ asserts position at the end of a line
For 2: constraint: . mod 5 = 0
See Math Operators about the mod operator; it returns the remainder after integer division.
