I am getting this below error, help me solve this issue.
Error: b"ODK Validate Errors:\n>> Something broke the parser. See above for a hint.\nError evaluating field 'sec_2': The problem was located in Relevant expression for ${sec_2}\nXPath evaluation: cannot handle function 'selected' requires 2 arguments. Only 1 provided.\nCaused by: org.javarosa.xpath.XPathUnhandledException: The problem was located in Relevant expression for ${sec_2}\nXPath evaluation: cannot handle function 'selected' requires 2 arguments. Only 1 provided.\n\t... 11 more\n\nThe following files failed validation:\n${Consumer_Questionnaire_ESCOM_V1}.xml\n\nResult: Invalid"
could you attach the xls form? I think the problem is caused by cannot handle function 'selected' requires 2 arguments. Only 1 provided
but I can't see in the attached screenshot.
For example in row 159 you have something like: selected(${hc202_1},'4' and ${hc205_1},'<60') it should be rather selected(${hc202_1},'4') and selected(${hc205_1},'<60') etc. another thing is taht we don't support using operators like > < <= >= in that function.
