I don't see any maven files for ODKBriefcase when checked out via mercurial
from Google code. Does anyone have any tips on how to modify/compile the
briefcase app? I'm guessing Eclipse with JDK 7 is the standard?
Joe
Correct. Eclipse, JDK 7.
w.r.t. maven, we will likely be migrating to gradle as the tools support
for that improves.
On Mon, Jul 7, 2014 at 9:33 AM, ODKUser wrote:Hi,
mercurial from Google code. Does anyone have any tips on how to
modify/compile the briefcase app? I'm guessing Eclipse with JDK 7 is the
standard?
Joe--
"ODK Developers" group.
And if you don't want to use Eclipse, the build.xml ant script from ODK
Validate might be useful.
https://code.google.com/p/opendatakit/source/browse/build.xml?repo=validate
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Mon, Jul 7, 2014 at 9:39 AM, Mitch Sundt mitchellsundt@gmail.com wrote:
w.r.t. maven, we will likely be migrating to gradle as the tools support for
that improves.On Mon, Jul 7, 2014 at 9:33 AM, ODKUser joseph.thomas.heenan@gmail.com wrote:
standard?
Joe--
mitchellsundt@gmail.com--
Thanks, compiled perfectly
