Hi All,
I have post a message in the ODK Community about my interest in ODK
Tables (awaiting moderation), right now I have the Android development
environment setup for ODK and already succeeded in compiling ODK
Collect and done some minor modification for my purpose but still have
problems for compiling ODK Tables.
Here is the output from my Eclipse Console:
[2012-05-23 08:53:17 - SpreadSheet] Dx warning: Ignoring InnerClasses
attribute for an anonymous inner class
(org.apache.commons.logging.impl.LogFactoryImpl$1) that doesn't come with an
associated EnclosingMethod attribute. This class was probably produced by a
compiler that did not target the modern .class file format. The recommended
solution is to recompile the class from source, using an up-to-date compiler
and without specifying any "-target" type options. The consequence of ignoring
this warning is that reflective operations on this class will incorrectly
indicate that it is not an inner class.
(org.apache.commons.logging.impl.LogFactoryImpl$2) that doesn't come with an
(org.apache.commons.logging.impl.LogFactoryImpl$3) that doesn't come with an
[2012-05-23 08:53:18 - SpreadSheet] Dx warning: Ignoring InnerClasses
(org.apache.commons.logging.impl.SimpleLog$1) that doesn't come with an
(org.apache.commons.logging.impl.WeakHashtable$1) that doesn't come with an
(org.apache.commons.logging.LogFactory$1) that doesn't come with an
(org.apache.commons.logging.LogFactory$2) that doesn't come with an
(org.apache.commons.logging.LogFactory$3) that doesn't come with an
(org.apache.commons.logging.LogFactory$4) that doesn't come with an
(org.apache.commons.logging.LogFactory$5) that doesn't come with an
(org.apache.commons.logging.LogFactory$6) that doesn't come with an
[2012-05-23 08:53:34 - SpreadSheet] Dx
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.IllegalArgumentException: already added:
Lorg/achartengine/ChartFactory;
[2012-05-23 08:53:34 - SpreadSheet] Dx at
com.android.dx.dex.file.ClassDefsSection.add(ClassDefsSection.java:123)
com.android.dx.dex.file.DexFile.add(DexFile.java:163)
com.android.dx.command.dexer.Main.processClass(Main.java:486)
com.android.dx.command.dexer.Main.processFileBytes(Main.java:455)
com.android.dx.command.dexer.Main.access$400(Main.java:67)
com.android.dx.command.dexer.Main$1.processFileBytes(Main.java:394)
com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:245)
com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:131)
com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:109)
com.android.dx.command.dexer.Main.processOne(Main.java:418)
com.android.dx.command.dexer.Main.processAllFiles(Main.java:329)
com.android.dx.command.dexer.Main.run(Main.java:206)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
com.android.ide.eclipse.adt.internal.build.DexWrapper.run(DexWrapper.java:179)
com.android.ide.eclipse.adt.internal.build.BuildHelper.executeDx(BuildHelper.java:745)
com.android.ide.eclipse.adt.internal.build.builders.PostCompilerBuilder.build(PostCompilerBuilder.java:634)
org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:629)
org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:172)
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:282)
org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:363)
org.eclipse.core.internal.resources.Project$1.run(Project.java:545)
org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1975)
org.eclipse.core.internal.resources.Project.internalBuild(Project.java:524)
org.eclipse.core.internal.resources.Project.build(Project.java:123)
com.android.ide.eclipse.adt.internal.project.ProjectHelper.doFullIncrementalDebugBuild(ProjectHelper.java:961)
com.android.ide.eclipse.adt.internal.launch.LaunchConfigDelegate.launch(LaunchConfigDelegate.java:146)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:853)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:702)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:924)
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1128)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Lorg/apache/commons/math/analysis/BinaryFunction$1;
Lau/com/bytecode/opencsv/CSVParser;
Lorg/opendatakit/aggregate/odktables/entity/serialization/SimpleXMLMessageReaderWriter;
Lorg/simpleframework/xml/Attribute;
Lorg/springframework/beans/BeansException;
Lorg/springframework/http/ContentCodingType$1;
Lorg/joda/time/base/AbstractDateTime;
java.lang.IllegalArgumentException: already added: Lorg/kxml2/io/KXmlParser;
Lcom/google/gson/annotations/Expose;
[2012-05-23 08:53:34 - SpreadSheet] Dx 10 errors; aborting
[2012-05-23 08:53:34 - SpreadSheet] Conversion to Dalvik format failed
with error 1
---I don't think that I need to change anything in ODK Tables, but I have
to do compilation because I can't find any link to download APK for
ODK Tables. Would really appreciate if anybody can send me one.
Thank You.
