In our survey, 5 questions were asked for each member that was employed in
the household, and this repeating group of questions was only skipped if
the respondent entered 0 for total persons employed. Otherwise, the
enumerator could ask this group of questions for as many people that were
employed.
This issue we are having now is that in the cells in excel that should have
this specific information, I am referred to the appspot.com website to get
it. We have approximately 4000 observations and this would be terribly time
consuming to go back for each household and copy this information off the
web. Is there a way around this/ a more efficient means in obtaining this
data? Thank you for your help in advance
You'll want to use ODK Briefcase to download and export your data. It will
export separate .csv files for any repeat groups.
Chris
On Dec 12, 2013 7:53 PM, wrote:
Greetings Community,
employed.
have this specific information, I am referred to the appspot.com website
to get it. We have approximately 4000 observations and this would be
terribly time consuming to go back for each household and copy this
information off the web. Is there a way around this/ a more efficient means
in obtaining this data? Thank you for your help in advance
Thank you for the prompt response. I downloaded briefcase, but my Mac won't
run it (unidentified developer). I tried using terminal to run the jar
file, but I am getting this:
Error: Unable to access jarfile path_to_jar. What should I do?
Adam
On Thursday, December 12, 2013 5:04:13 PM UTC-8, Christopher Robert wrote:
> Adam,
> Best,
> Chris
>> in the household, and this repeating group of questions was only skipped if
>> employed.
>> Sincerely,
>> Adam
>> "ODK Community" group.
>> For more options, visit https://groups.google.com/groups/opt_out.
I am able to open briefcase on a school computer, but am having trouble
actually using it. I don't really understand the information on the actual
ODK website- can you maybe give me a brief summary of how I use it to get
the information off the aggregate website? No matter which URL I use, I get
an error message of "Unable to fetch formList," or something along these
lines. Thank you
Sincerely,
Adam
On Thursday, December 12, 2013 5:35:43 PM UTC-8, adamks...@gmail.com wrote:
> Hello Chris,
> won't run it (unidentified developer). I tried using terminal to run the
> jar file, but I am getting this:
> Thanks,
> Adam
>> Adam,
>> will export separate .csv files for any repeat groups.
>> Best,
>> Chris
>>> employed.
>>> have this specific information, I am referred to the appspot.comwebsite to get it. We have approximately 4000 observations and this would
>>> be terribly time consuming to go back for each household and copy this
>>> Sincerely,
>>> Adam
>>> Groups "ODK Community" group.
>>> an email to opendatakit...@googlegroups.com.
Click Connect, put in the URL you use to access your server (like " https://yourname.appspot.com"), your username, and your password. Hopefully
it will Connect okay and list the forms on your server. Then, check off
forms to pull down to your local computer. After that, switch over to the
Export tab to export those pulled forms to .csv files.
Chris
On Thu, Dec 12, 2013 at 9:32 PM, wrote:
Greetings,
lines. Thank you
Sincerely,
Adam
On Thursday, December 12, 2013 5:35:43 PM UTC-8, adamks...@gmail.comwrote:
Hello Chris,
Adam
Adam,
employed.
On Friday, December 13, 2013 3:40:05 AM UTC-8, Christopher Robert wrote:
> Hi Adam,
> Hopefully it will Connect okay and list the forms on your server. Then,
> check off forms to pull down to your local computer. After that, switch
> over to the Export tab to export those pulled forms to .csv files.
> Best,
> Chris
> On Thu, Dec 12, 2013 at 9:32 PM, <adamks...@gmail.com >wrote:
>> Greetings,
>> lines. Thank you
>> Sincerely,
>> Adam
>>> Hello Chris,
>>> Thanks,
>>> Adam
>>>> Adam,
>>>> Best,
>>>> Chris
>>>>> employed in the household, and this repeating group of questions was only
>>>>> skipped if the respondent entered 0 for total persons employed. Otherwise,
>>>>> the enumerator could ask this group of questions for as many people that
>>>>> were employed.
>>>>> Sincerely,
>>>>> Adam
