Dear ODKians,
I have created repeated or looped event group with constraint based on
answer of previous question.
For example:
Question 1: ID
Question 2 Repeated Group Question: name of the categories where ID = '100'
when I give ID as 123 and swipe to next question, It says "Add New Group?"
-dialog then if I select "Add Group" then it shows "And One More Group"
dialogs repeatedly.
What is expected is we should not show any dialog box's, it has to show end
screen.
I have attached sample xforms for your kind reference, Kindly suggest me to
resolve this issue.
Thanking you
RES
TestForm.xml (1.7 KB)
Filed at http://code.google.com/p/opendatakit/issues/detail?id=535.
Please star the issue to get updates.
This actually isn't a bug. The problem is that the relevance needs to
go on the group tag, not the repeat tag. We'll add some documentation
to http://opendatakit.org/help/form-design/binding and close the issue
when we do.
On Thu, Mar 15, 2012 at 08:29, res tester wrote:
> Dear ODKians,
> For example:
> Question 1: ID
> dialogs repeatedly.
> screen.
> resolve this issue.
> Thanking you
> RES
