Unable to load specific odkbuild file using "Load form from file"
I am trying to load an old odk build file so that I can make new edits to it. I have the old file with an .odkbuild extension saved to my computer. When I try to load it using the "Load form from file" feature, nothing happens. However, when I try to load any other .odkbuild file on my computer, it loads quickly without issue.
I am using Google Chrome.
Any tips for why this file may not be loading, or how I can get it to load? It is of a comparable size and age to the other odkbuild files I AM able to open.
Thank you!
.odkbuild is a JSON file. Rename the extension to JSON, open it in a
text editor and see if anything looks different or corrupt.
ยทยทยท -- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.
Thank you!
